Jackeroo Tuscan sz BBQ manual - Computers & Internet
Need assembly instructions for a jackaroo flinders 4 burner bbq
It is a discontinued product so you are probably going to have to just lay all the parts out and guess. You could also look for assembly instructions for a similar BBQ made by Weber. They all follow a logical sequence.
I did find reviews, you could ask if anyone has the manual and when you ask a question, the question is sent to those who have reviewed already.
Jackeroo Flinders 4 Burner
Dec 28, 2015 | BBQ Guys Grilling
How can a roast chicken,beef or pork in my patio bbq? how many burners should I use with the bbq covered? should be on hi or low ? how many degrees 200? or more?
Hi Gary....advise make and model of your bbq and I will
try and find out where you can get a manual..
Regards,
Dennis
Oct 13, 2014 | Grilling
Installing clutch pedal holden jackeroo 1992
a jeep jackeroo? huh.
was your jeep , hijacked?
Apr 13, 2014 | 1994 Jeep Wrangler
I have a jackeroo 6 burner hooded bbq and when i try to light more than 4 burners on high they all blow out, i have cleaned the burners of any rust that might be blocking flow but it is still happening,...
Try lighting them slower allowing the heat to build, you want the grill completely heated before cooking. If this does not help a couple more situations may be effecting the grill; look at your grills placement... maybe too close to major drafts (ie. as in an upper floor balcony) check to see if your regulator is giving you problems and the valve is open 100%. Assure that your tank is not almost empty. If you are in a cold weather area then prior to cooking bring your tank into a warmer area as temperature can effect performance. I use to live in South Dakota and in the Winter the tank came in the house.
Jan 13, 2013 | Grilling
No instructions with the Jackeroo Wentworth WL BBQ
http://www.grandhall.com.au/downloads/4/ Your Jackeroo was manufactured by grand hall and while your particular model was not listed it seemed that there is a similarity on several of the models, see if one of them is close to your BBQ.
Jan 11, 2013 | Grilling
Need a manual for a Jumbuck Endeavour 4 MKII BBQ.
Need assembly instructions for a Voyager 4 Jumbuck BBQ, no more than two years old. Our daughter recently moved, the BBQ was dismantled by the removalists and she is now unable to find the assembly manual.
Many thanks
Rod Gilbert - rod.gilbert@hotmail.com
Apr 20, 2010 | Grilling
Need a Manual for Turbo STS Elite 4 burner BBQ - HELP!
if you havent already done it call bbq galore 214 696 0030
Sep 08, 2008 | Barbeques Galore Turbo Elite 4-Burner with...
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
