Question about Siemens Seimens Arc Fault Breaker
Poped breaker PC pops breaker
  • David Robinson May 11, 2010
    Hello. Are you saying that your personal computer is popping the breaker?
    Problem Solver:
  • 12 Answers
In canada arc fault breakers are used for the housing market, to protect bedrooms. For years we haven<t had a problem without them being installed.. Your pc should be plugged into a regular receptical and have a surge protector plugged into the wall outlet and your pc into the surge protector. This will protect you from lightning surges and if the problem insists, check to make sure you may have to many other recepticals (plugs) wired on the same circuit.
Posted on Jan 25, 2009
Ptac not heating
Power? Check breaker. If poped, reset try again. If pops again you have an electrical problem. Could be dangerous. If power is good, the thermostat or heat button switch is bad. How old is Ptac? You may need appliance tech. The voltage is probably 220vac. If you don't know what your doing it's dangerous to troubleshoot. If it's still under warrantee I'd go to MFG.
Feb 26, 2015 | Heating & Cooling
My champion generator 9000 watt breakers keep poping
How much time have the Generator?
looks like batteries needs to change it.
Aug 11, 2014 | UPG 12V 18Ah Champion Generator 9000 7000...
I have a 4 yr old vx6000c central vac that constantly blows house breaker
This unit requires a 15AMP 120 VOLT dedicated circuit. If there are other appliances or items on this central vacuum circuit, this could overload the circuit causing it to pop. The other issue that could be occurring is that the central vacuum is on a GFI circuit or ARC fault circuit. Central Vacuum Units are not designed to run on these types of electrical circuits.
Please visit our website if you need a replacement part or if you have more questions. Or give us a call at 1-800-533-3249
Don't forget to like and visit our Facebook page.
https://www.facebook.com/QualityHomeSystems/
Jun 06, 2014 | Broan-NuTone Vacuums
I have a new paddle light switch im trying to install and for some reason it keeps poping the breaker. im wondering if im installing it correctly
make sure you are hooking up the correct color wires to it main wire on top of switch, bottom wire of switch other color wire they should be blackor any other color , just dont hook up the white wire to it this will make your breaker pop , If your copper is touching any metal this will make it pop also,good luck
Jul 29, 2011 | Cooper Industries Cooper Wiring: Single...
New heating element pops circuit breaker
Obviously something is shorting out. Check all wiring.
Oct 31, 2017 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Keep poping the breaker on instllation
Check your wiring for short circuits. If you turn the switch on and it pops it may be in the switch box or up in the fan box. Also make sure the fan blades spin freely. A motor overload or short circuit would be the only reason for the breaker tripping immediately.
Jan 10, 2010 | Hunter Sontera 52" Ceiling Fan with...
Bosch 24 in. SHE44C05UC pops breaker
We just had a potentially dangerous problem with the same model. Only we found the wiring beneath the front door were fried. How do yours look?
Dec 31, 2009 | Bosch 24 in. SHE44C05UC Stainless Steel...
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Heard popping noise and circuit to stove blew. could not set time or oven temp when reset breaker
Hi
Sounds like your oven heater failed. Not sure if its a fan oven or static type. If you hear a fan inside the oven then its classed as a fan oven
Nov 16, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Nordyne air cond Model E2eb-017HB got wet, shorted out
sounds like you experienced an ice over. this can destroy the compressor. if contactor is humming the call for cooling is present but the breaker poping is cause for concern. possibly needs new compressor.
Aug 23, 2009 | Heating & Cooling
Siemens Seimens Arc Fault Breaker Logo
218 people viewed this question
Top Siemens Electrical Supplies Experts
Steve
john h
Mike
Are you a Siemens Electrical Supply Expert? Answer questions, earn points and help others
