Question about Belkin Computers & Internet
Problem with Ubee Wireless Play Router (DVW3201BB8)
The wps is blinking and i can't get wi-fi
cnavarro
  • 2460 Answers
SOURCE: How to get wi fi at home for itouch?
Your better bet is a wireless access point. It plugs into your router and can be configured to be transparent to the network so that any IP address you get for your wireless device comes from the original router (better for networking).
At the blinkingly fast speeds of your Wireless internet, "N" is a waste. Get the "G". Here's a link to the product I would use...it runs about $50. http://www.tplink.com/products/product_des.asp?id=116
Carl
Posted on Feb 27, 2009
anandg27
  • 1272 Answers
SOURCE: connecting my ipod touch to my wireless router through wi fi
Check for the password on the router configuration page to make sure tat you are using the correct one:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
Enter the same password on IPOD to connect to the wireless network.
Rate it,if it helps.
Posted on Jun 26, 2009
  • 192 Answers
SOURCE: my d-link 2640t wireless router suddenly no Wi-Fi
This one can be one of two things.
If you have a digital multimeter, check the power connection and make sure that it's not to high (eg. 7.5 V DC should read no more than 7.8 V for it to work properly)
Otherwise, just reset the router. I have a feeling it is the first one.
Once it reaches to 130% above of what's rated, it can fry your network adapter in your computer and possibly more damage if it's wired.
Posted on Aug 09, 2009
SOURCE: Connecting wi-fi blue-ray disc player to router
No solution, but why doesn't Samsung make this a little more user friendly... I am not a electronics geek, and I set up my PS3 in 5 minutes, and still can't figure out the Samsung Blue Ray player... contemplating just carrying it back for a refund!!
Posted on Dec 07, 2009
dean66
  • 22 Answers
SOURCE: D-Link wireless router & Ubee modem - which router ports
All routers will have a in for you modem, but your outlets wont matter what you use they are normally numbered 1-4 or 1-5. you can use any outlet and your pc will pic it up, they dont have to be in order through the ethernet.
Posted on May 17, 2010
WPS button
I have a WRT54G router and there is no WPS button.
This is a cut and paste from Cisco engineer:
Wi-Fi Protected Setup or WPS is a somewhat new feature on most routers. However, I believe that the WRT54g was release prior to this feature. The installation disc for your wireless adapter is trying to circumvent network discovery and the process of entering a wireless password by using the WPS feature. Without using the installation disc to setup the adapter should still be able to connect to your Wi-FI network. Only use the disc to install the drivers for your wireless card and the wireless access utility. After you have done this:
1.Open the wireless utility and you should see available networks
2.Select your Wi-Fi network
3.If the network is open (not password proctected) you should be connected immediately
4.If the network is secured (password protected) then you will prompted to enter your password or preshared key
5.After entering the key you should be granted access to the network
Apr 19, 2014 | Linksys Wireless-G WRT54G Router
Wps button
The front of your Actiontec modem has a button and light for Wi-Fi Protected Setup (WPS). If that button was pressed or the WPS process was started, that button may light up or blink.
Aug 16, 2013 | D-Link DIR-625 (790069292637) Wireless...
Wi fi protected setup
In the printer setup, wireless is on? No list of available wireless networks? Do you have to make the printer discoverable? You didn't supply the Model of Brothers printer?
Jan 26, 2013 | Actiontec GT704WG Wireless Router...
Wps light blinking
CALL YOUR ISP FIRST.
wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices. WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either on the product or a clickable button on a wizard or utility screen.
Jan 22, 2013 | Netopia Motorola 2247-n8 Wireless Dsl...
Hp printer says to press the WPS button on the router. What's that?
  • Wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections.
  • WPS lets you use push buttons or PINS instead of entering a network name (SSID) and wireless security by hand.
  • Push button: The WPS button is either on the product or a clickable button on a wizard or utility screen.
  • Personal Identification Number (PIN): The PIN is either on a product label or can be viewed on a wizard or utility screen. The PIN is entered for either the router or access point, or for the wireless device that wants to join the network.
Feb 01, 2012 | Linksys Computers & Internet
What's your problem?my ipod is asking for password to connect to wi-fi, what is my password? How do I find out what my password is?
Go to the Belkin setup page (http://192.168.2.1/index.asp) and select Wireless 1) Wi-Fi Protected Setup(WPS)
Select
2) Push Button Configuration (PBC) Method Push and hold PBC button on your Router for 3 seconds or click "Start PBC". Then start PBC on the device you want to connect to the Router within 2 minutes.
Oct 01, 2011 | Belkin Basic Wireless Router
How to setting the wi fi
hello, try this things ok
WPS stand for Wi-Fi Protected Set-up . According yo Wikipedia "The goal of the WPS protocol is to simplify the process of configuring security on wireless network, If your 2Wire router is equiped with that function it would be the BIG button on the bottom front of your router Look at this advertisement from 2Wire http://2wire.com/movies/pages/112.swf
im sure in can help you.
Sep 02, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
I am trying to set up my hp printer and I am trying to find the wps button on my 2wire router that the set screen is telling me to press. But I don't see one on it. Does 2wire support WPS, what ever...
Hello pbufordjr,
Aug 04, 2011 | 2wire (2701HG-B) Wireless Router
Does my WRT160N have a WPS button and if so, where is it?
The Linksys WRT160N has WPS (Wi-Fi Protected Setup). If you are using WPA-PSK encryption (recommended), then you can easily connect the C4780 to your wireless network using WPS:
1) On the Linksys router, press the WPS button that is top of the case just under the Cisco label. When the LED on the button starts to blink, then the WPS process has started.
Jul 06, 2011 | Linksys WRT160N Wireless Router
There is a green light on on top and after i push the wps button a red light blinks for a while and then stays on any ideas the laptop that has been used with this router is not getting a connection now...
WPS means Wi-fi Protected Setup its a kind of wireless security for the router. There are two methods of activating it either by push button(Which you tried) and other is manual for that you can log into the Router setup page using "Http://192.168.2.1" in the Internet explorer and enter the pin code printed under the router. You should click on "Wi-fi protected setup" towards the left side of the page and leave the password field blank and click submit and enter the code and click on "Start" or Apply changes. The reason why it didnt work through the button is probably because your laptop might not be in range or switched off. It has a utility installed on your laptop which recognizes the connection and let it protect using WPS.
Hope it helps. Please feel free to contact us for further assistance or information.
Dec 16, 2010 | Belkin Basic Wireless Router
Computers & Internet Logo
55 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
