Question about Watches
How to change time on WR30M us submarine digital watch
Wont let me change the time
SOURCE: Changing the DAY on this analog watch.
Turning it backwards didn't work on my watch. I ended up winding the time ahead several days worth to show the right day of the week (being careful to turn it to the correct 9 o'clock of the day, for me is was the first for morning.) Then I could go ahead and change the date using the first click postition of the stem.
I see that light bulb going off and you whispering "why, of course!"
Posted on Apr 03, 2008
SOURCE: Setting Time and Date on a Timex WR30M
1) Press and hold mode for about 2 seconds and then release. You will now be in the alarm edit mode.
2) Press mode once more and now you are in time edit mode.
3) Use the stop button to select what to edit, i.e. hour minute, etc.
4) Use the reset button to make the changes once you have selected the hour/minute, etc. that you want to change.
5) Press
Posted on Nov 18, 2008
  • 1139 Answers
SOURCE: I have a WR30M watch
Follow these steps to adjust the time :
Step 1. Press and hold MODE for 2 seconds and then release. The watch will be in alarm mode.
Step 2. Press mode again to enter time mode adjust.
Step 3. Press the stop button to cycle through what you want to adjust.
Step 4. Press the reset button to adjust the actual item.
Step 5. Press MODE to exit time setting mode.
Hope this helps
Posted on Nov 24, 2010
SOURCE: HOW TO CHANGE THE TIME
Press "mode" until the hour is flashing,
Now press "start" to change the hour. When hour is correct, press "reset" and minutes should start flashing.
Press "start" to change minutes" then press "mode" again.
Posted on Dec 18, 2010
SOURCE: i need instructions for digital
Go to this web site it should help:
www.buydakotawatches.com/PDF_FILES/Digital.pdf
Posted on Feb 19, 2011
How to set the time on a wr30m watch
google how to set time on a wr30m watch
Sep 10, 2016 | The Watches
How do I set the time on my pasnew watch
Dealextreme - PASNEW Sport Waterproof Quartz Analog ...
? 6:32
https://www.youtube.com/watch?v=7D6i4d-1NYQ
Oct 25, 2011 - Uploaded by TheTemplegeek
... PU watchband - Dual time display: analog and digital - Features timer, ... PASNEW Sport Waterproof Quartz ...
How to set watch model WR30M - YouTube
? 3:02
https://www.youtube.com/watch?v=VGRAb0aF2lQ
Apr 29, 2015 - Uploaded by TheUltimate
11:24. How to Set a Timex Ironman Triathlon Watch - Duration: 1:15. by Inside Endurance Sports 2,441 views ...
how to set time in digital watch - YouTube
Dec 15, 2015 | Watches
Instructions for Bowflex WR30M?
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen.
In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped.
In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again.
Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again.
To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
Apr 13, 2012 | Watches
How to change the date on a Mingrui WR30m watch and also the day setting unless these are corordinated?
Keep on clicking on mode until it comes up with the seconds flashing. Then click on reset 5 times until the day is flashing. Then click on start until the day changes to the day you want! :D It worked for me
Sep 25, 2011 | Watches
I need instructions for digital umbro watch WR30M
Nov 23, 2010 | Watches
How do i change my timex wr30m from 24 hour to 12 hour display
Hi cbrichw,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Nov 13, 2010 | Timex 1440 Nylon watch
HOW TO CHANGE THE TIME ON MY DIGITAL WATCH IT HAS 4 BUTTONS ON THE TOP LEFT IS "LIGHT" ON THE LEFT "MODE" ON THE TOP RIGHT "START" AND ON THE RIGHT IS "RESET" THE...
Oct 29, 2010 | Watches
THE MARKERS AND POINTERS OF MY ROLEX SUBMARINER ARE NO LONGER LUMINOUS IN THE DARK. CAN THEY BE RE-COATED? ANY IDEA OF COSTS INVOLVED
They can be re coated or replaced.The watch will need to be re sealed after so now may be a good time to service the watch as this is advised every 4/5 years.
A service will cost £275.00/£325.00 and takes 2/3 weeks at www.rolexrepairs.co.uk
Regards
Aug 09, 2010 | Rolex Submariner 16618 Wristwatch
I have a rolex submariner and it occaisonally vibrates. What is the problem with this.
Sounds like mainspring is not holding in place and getting undone (unrolls by itself), that what usually causes the vibration.
W-Precision
Mar 19, 2010 | Rolex Daytona 116520 Wrist Watch
Watches Logo
158 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
