Question about Siemens Seimens Arc Fault Breaker
Tripped breaker pc pops breaker
  • 5,568 Answers
Try another load, a healthy one such as a toaster or coffee maker on the same circuit (preferably the same outlet) to see if the breaker is at fault. Conversely, you should try the PC with an extension cord, in a known different circuit srviced by a different breaker.
For whatever reason, breakers don't seem as durable as they once were; in a new home, two of ~20 failed when new.
If you establish that it is the PC causing the fault, new power supplies start at ~ $20 (on line-dealers charge way more) and it is a fairly simple procedure to replace it.
I suggest you take some snapshots of the guts of your machine after exposing the innards and remove the sick supply and physically compare it to those offered on eBay and elsewhere.
The most important parameter will be the total power output of the supply, its rating in watts; as in 450W. You can safely (and it is advisable) to step up in power when replacing these and the cost difference is minor. i.e.; if your current supply is 350W, go to 400 or 450 watts.  The new supply will run under less stress and probably live longer.
Posted on Jan 22, 2009
MET8665XS00 will not turn on
Check to see if there are any terminations from the breaker to the range...could have come loose. You will probably need to check the voltage @ the breaker & make sure it is feeding out. Also pull you range & check the back terminations for tightness.
Dec 17, 2013 | Kitchen Ranges
Electronics breaker keeps tripping switched
write down all auxs then unplug all then turn on and plug one at a time till it pops probably heater ignitor if ok bad pump motor
Aug 18, 2013 | Pentair Intellitouch Power Center Includes...
Pentair intellitouch electronic breaker keeps tripping
check pump see if popping or heater unplug auxs until it doesn't pop if keeps maybe bad transformer
May 04, 2012 | Pentair Intellitouch Power Center Includes...
The stove made a popping sound and the circuit breaker popped.i reset the breaker and it popped instantly.
Since you have a gas kitchen range, finding the problem should not be that difficult.
1. Make sure all switches are in the off position. Then reset the circuit breaker. If it didn't trip, then turn one knob on at a time (and then off) until it trips.
2. If the circuit breaker triped with all knobs off, then it would have to be something that is always on like the 12V transformer.
Hopefully, this wiring diagram will be of help.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Range-Parts/Model-MGR6772BDS/3048/0124002/M0604023/00009
Jun 23, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
My Fridgidaire FEF366BCC just popped my breaker
This sounds like a main control problem. More specifically like one of the relays is shorted. You will need to acess the main control and carefully inspect it for any burn marks. If you don't see any disconnect the main power supply wire going to the main control. Then plug it back in if it trips the breaker the problem is in the power cord or wiring from the cord junction to the main control. If it does not trip the breaker the problem is the main control. Here is a link that should help http://appliancehelponline.com/ovenerc.html
Jul 21, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Blows circuit breaker
sounds as if there is a short in the starting switch but there is a short somewhere in the controls good luck
Dave
Sep 15, 2009 | Amana ALE331RAW Gas Dryer
Hitachi RAS09UH randomly pops 15A circuit breaker
Two things that you could check: 1) If you have access to an ampmeter, determine if the unit is drawing over over 14 or 15 amps, 2) replace the suspect circuit breaker in case it is beginning to go bad. Breakers only trip for overcurrent conditions or failure of the breaker itself. If it is pulling close to 15 amps, then it could heat up over time and trip.
Jul 09, 2009 | Hitachi RAS-09UH Air Conditioner
Dishwasher pops the circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jul 01, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Siemens Seimens Arc Fault Breaker Logo
244 people viewed this question
Top Siemens Electrical Supplies Experts
Craig Butler
Craig Butler
john h
Steve
Are you a Siemens Electrical Supply Expert? Answer questions, earn points and help others
