Question about Maytag MAH2400 High Efficiency Front Load Washer
What do I do for my maytag MAH2400 front load washer, I get SUDS error on every load?
I use HE soap, I have run vinegar through a number of times, I have run the machine through complete cycles with nothing in it, I do have dogs and cats, so I am always pulling out hair balls. I was wondering if anyone could tell me if there is away to check for hair balls in the pump or under the tub?
  • 3 Answers
SOURCE: Maytag front loading washing machine
This worked for me for the E3 error code: Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord. This dumps the memory. Evidently, if it gets full, it causes problems with the programming and messes up the cycles.
Posted on Jun 20, 2008
3E = Drive system is not working correctly. Bad windings, speed sensor, wiring connections or Control Board.
Posted on Aug 25, 2008
  • 155 Answers
SOURCE: Ld error on Maytag Bravo. How to remove items stuck under tub?
if you can see the socks you may be able to remove by making a wire hook with an old coat hanger or something similar if you are able to undo the hose coming out of your bowl to the water pump you may be able to also fish out the coins if you are lucky but the best way is to dismantle bowl let me know how you went
Posted on Nov 07, 2009
SOURCE: Maytag Neptune MAH8700AWW Front Load Washer doesn't always drain
Need to see a picture of how to take off the front loader
Posted on Jan 23, 2010
SOURCE: I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Posted on Feb 06, 2010
How can you reset the suds error code message on a may tag Neptune washer?
Try running a load without adding anymore additional soap and see if you can get it to go through the cycle, you may have to try it several times. I would also suggest cutting the amount of soap down to help prevent this in the future.
Jun 23, 2015 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Front load Washer. "SUDS"
Clean the drain pump basket. http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump+cleaning&oq=Kenmore+Elite+Front+Load+Washer+drain+pump+clean&gs_l=youtube.1.0.33i21l2.425000.427123.0.432800.6.6.0.0.0.0.410.1517.2-5j0j1.6.0...0.0...1ac.1.lQhVllMwg9M
Jan 27, 2013 | Maytag MAH2400 High Efficiency Front Load...
I have a Whirlpool 9500TC Front Loader Washer. Can't wash garments due SUDS Display. Can't use any washer functions due to SUDS display.
Run a cycle with white vinegar this will clear the suds. Make sure you are using HE soap if not the unit will over suds.
Another common issue is the drain pump filter. If it gets clogged the sud error will come up as well. If you have water inside the pump may need to be cleaned. Simply remove the three screws ont he bottom of the lower access panel and then twist the handle on the filter. If water is inside the washer, it will come out when the filter is pulled out.
Good luck with your washer repair friend.
May 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code ''suds'' on maytag front loading washer
Press Chime and Extra rinse keys for three seconds or until the control beeps. You are now in service mode and your machine should say a new error code. Depending on what that code is, you might be able to reset your machine by unplugging it, and replugging it in. if your codes are now clear, try running machine on spin only or rinse cycle. DO NOT add more soap!!! If this corrects your problem, try running a load with out soap. You may have a lot of extra soap in your machine.
Mar 20, 2010 | Maytag MAH8700A Front Load Washer
Suds error
http://www.servicematters.com/maytag_library/docs/16025909.pdf
Here is the service manual for your machine.
When you get the suds cleared out you must use H E soap and or less soap.
You may need to run 3 or 4 cycles with no clothes at all to clear out the existing suds.
Mar 11, 2010 | Maytag Neptune MAH9700 Front Load Washer
"suds" error in kenmore elite HE3 front loader washer
Try a vinegar rinse or there are also defoaming products available.
Jan 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
SUDS error on Neptune washer
It means that there is too much soap in the machine most of the time. Give it time for the suds to go down then try to run it through again. Try using a little less soap later on. Front loaders need less soap than top loaders.
Nov 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Duet Front Load Washer WFW8300SW00 Problem: I am using HE detergent and using less than the recommended amount; however, there is always a small ***** of suds sitting on the seal when I open the...
If you have a water softener or very soft water, soap will suds up more than if your water is normal or hard, so you'll need to use less than recommended. Obviously soap breaks down the dirt, but the dirt also breaks down the soap, so if your clothes are not very dirty to start with, you'll need less soap than if they were more dirty. Soap can also be stored in laundry like towels and cleaning rags and when combined with the laundry soap will suds more. You can try raising the leveling legs in the front to tip the washer back. This will help the water drain back into the tub instead of pooling on the boot. You can also try using the 'extra rinse' option. Keep cutting back on how much soap you use until your laundry is not as clean as it should be. You might be surprised how little soap you can use!
Jul 21, 2008 | Whirlpool Washing Machines
Error code SD
I work for an appliance company in the service department, and what this really means is that you could have a suds build up in your machine, or that you used too much soap on this particular cycle. If starting over does not work, you can buy a product called washer magic at almost any store and it will clean your machine out. Also, running vinegar through the machine will make any suds dissapate.
Nov 14, 2007 | Maytag Neptune MAH6700A Front Load Washer
Maytag MAH2400 High Efficiency Front Load Washer Logo
16 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
