Question about Element ELC-HS321 32 in. LCD TV
How to turn off overscan - Element ELC-HS321 32 in. LCD TV
Repaired the convergence and now the image quality is good but the TV seems to be over projecting the screen. The top, bottom and sides of the image are cut off slightly. is there a way to adjust?
Hey! its me again. I think what your experiencing is called overscan. This website might help but if not just google how to fix overscan on a projection tv.
http://www.cnet.com/news/overscan-youre-not-seeing-the-whole-picture-on-your-tv/
May 24, 2016 | Televison & Video
How do I enter the service menu on an Emerson EWF2004 CRT Television? (Pictures of the OVERSCAN ISSUE will be provided if needed.)
Older sets had vertical and horizontal size controls. If you have the horizontal size control, turning it counterclockwise will reduce the size of the picture horizontally and reduce the overscan.
Feb 25, 2016 | Emerson EWF2004 20" TV
How do I fix overscan
It might be your signal source. You do not give enough information to properly diagnosis the problem.
Nov 27, 2014 | Televison & Video
Setting up tevion receiver
I did not find the Overscan, however I changed the TV settings, hdmi to digital, and this worked. Also, I did have part of the screen missing. I called the Tech Support to setup my Mac Mini and they adjust the Overscan on the Mac System Preferences, all is fixed. Thanks for yawl help.
Jun 03, 2012 | Televison & Video
AOC monitor 2436vh does not fill the screen using the HDMI connector. There is a 1 inch black border around the window. Controls to stretch the display are locked out (not accessible) when using that...
The "Best Solution" fixes a problem that is unrelated to the original poster. anononline19's solution is to fix the entire OSD being locked (displays OSD Locked when the menu button is pressed).
Original poster's problem can be fixed by changing your graphics card's "overscan" settings.
Overscan on ATI cards:
http://nigelt.wordpress.com/2009/09/21/overscan-options-in-catalyst-9-9-on-windows-7/
Overscan on nVidia cards is currently not supported.
Oct 16, 2010 | AOC Computers & Internet
Television vertical overscan
Hello!
Please check the "Troubleshooting" part of the manual to this TV.
https://manualsbrain.com/en/manuals/1874651/?page=24
Aug 31, 2017 | Insignia Televison & Video
Overscan
do you mean the top of the picture is cutt off? if so then go into tv menu and set screen size to 16:9 not auto. if that doesnt work then try settings on ps3 hopefully that works
Jul 23, 2008 | Toshiba 55H70 55" Rear Projection...
Picture is much too big
try the P-size button on the remote control
Jul 13, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Magnavox 37MF337B/37 overscan only sometimes problem
This TV has a pixel resolution of 1366x768p
It will accept a 1920x1080i input from a high def source , but running a PC at 1920x1080i/p will cause the problems you describe, depending on what the PC is sending to the TV, because PC signals are not the same as high def.
Your PC should be set to a resolution as near to 1366x768 as possible. My PC allows 1280x768 and 1360x768. Try one of these for best results.
There are no settings on the TV to solve this problem.
Feb 06, 2008 | Philips Magnavox 42MF521D/37 Television
My LG HDTV is in overscan, can't resolve
Have you tried to reduce the ratio on the remote..when zoom comes on lower the zoom ratio.
Dec 23, 2007 | LG 37LC2D Television
Element ELC-HS321 32 in. LCD TV Logo
96 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
