Question about Kenwood KAC-929 Car Audio Amplifier
My kenwood kac-929 amp keeps clicking and sub not working
My amp stays powered but clicks and the sub does not work
4 Suggested Answers
  • 216 Answers
SOURCE: Kenwood KAC-929
From the Input of amp, just connect cheap speaker with wires to input of amp.
If you have sound from speaker, most likely the amp is bad or loose connection.
Posted on Dec 26, 2007
  • 7 Answers
SOURCE: my kenwood amp
you need to check your wiring and check your rca wires to see if they are giving your amp a signal to put out
Posted on Nov 02, 2008
  • 77 Answers
SOURCE: kac - 929 kenwood 1000 watt amp
Does it do it when car is not moving? If it does'nt then it is a bad connection in the amp itself or outside the amp. Check all your external connection well, it is easy to pass a bad connection up without knowing it. I recomend checking every connection, redoing the connections. Then you can rule that out and may find the problem. If connections don't fix problem let me know i'll be glad to help. I have my own amp repair business and people send me there amps from all over the U.S. Just send me a message and
I'll take you thru some steps to diagnose the amp if problem persists after connection checks. Good luck, hope to hear from you!
Posted on Aug 02, 2009
My kenwood kac-929 amp is melting my ground cable help
That amp needs 4 gauge power and ground wire minimum. Too small of wire is just like using too small of a water main to a house....it's just not gonna work out
Jun 05, 2010 | Kenwood KAC-9152D Car Audio Amplifier
My subs/amp are not working
when you car is running, it charges the battery somewhat. So the voltage problem is not a problem. The red light means the amp is going into ''Protect Mode". This usually happens when something is wrong with the amp. Usually the amp is getting hot. Check all of you connectiong and check the final impedance of the subs. Make sure the amp can handle the impedance of the subs. If you need anymore help, message me.
Feb 12, 2010 | Kenwood Excelon KAC-X621 Car Audio...
Can you power 2-10" subs and 2-6x9 speakers with this amp?
You could but the only problem is even if you ran the speakers in parallel, meaning + to + and - to -, the best power you would get out of the amp is 230 watts per channel. Would probably make your 6x9 sound good but not enough to push your 10's.
Nov 19, 2009 | Kenwood KAC-929 Car Audio Amplifier
My kenwood kac-929 1000w amplifier is not powering my sub
unless you are a technician do not mess with the amplifier.
it takes years of school to learn electronics. unless it is a blown fuse or something simple,you will never fix it.
i did kenwood warranty for 8 years and the amplifiers are difficult to repair.
Aug 19, 2009 | Visonik V117SX Car Audio Amplifier
Amp keeps going off & on
sound like you have a loose power conection check them all
Apr 05, 2009 | Kenwood KAC-X501F Car Audio Amplifier
No sound from my woofer
Check your speaker connections... try using a multimeter set to "OHMS" and see if the speaker is reading around 4-8 ohms... if it shows no reading there is no continuity in the coil of the speaker
Mar 24, 2009 | Kenwood KAC-929 Car Audio Amplifier
My kenwood amp
Mar 11, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-929
Dec 25, 2007 | Kenwood KAC-929 Car Audio Amplifier
Kenwood kac-9152d
by jump do you mean all it does is thump and no sound besides thumping noise? if so put a better ground on your amp, double grounds work the best. please reply
Oct 06, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-929 Car Audio Amplifier Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
