Question about BenQ Joybook 8000 Notebook
Just got a toshiba notebook and when I try to get to the internet it says that it can not find the network adaptor, but it does not make sense for the adapter is in the notebook.
  • Josh Marquez May 11, 2010
    Is the laptop plugged into the AC adapter?
    Sometimes when a laptop is unplugged it will automatically disable the network adapter in order to save on power.
    Other than that it could be the driver missing.
    Keep me updated...
Lost wifi connection over night
You need to reinstall the wifi drivers.
Alternatively you can use the Microsoft troubles shooter by going to the control panel, picking network and sharing centre, then adaptor settings and selecting your adaptor. Then right click and from the menu, select diagnose. This will reset the adaptor if it has become locked up.
Jun 25, 2014 | Toshiba Computers & Internet
My toshiba satelite won't connect to the internet and i get an error message saying its my network adaptors. does this mean its a software problem or will i have to physically remove and replace the...
Hello.
Test your laptop at a different location to see if any difference.
If still the network adapter, first try to update the driver by going to Device Manager, find the network adapter and select update. You'll actually be reinstalling the current driver software.
If still a problem, the network adapter would need to be physically removed and replaced.
Hope this helps.
May 20, 2011 | Toshiba Computers & Internet
Toshiba wont charge
Sound like you may have the wrong power cord for your unit. The original power adaptor for the A105 is 75W (15V x5A) Auto sensing 100-240V/50-60MHz frequency input. If you got a replacement adaptor, I would reccomend a 75W or higher adaptor. (A new opposed to a used one.) Good Luck.
Feb 02, 2009 | Toshiba Satellite A105 Notebook
More signal and run faster
The only way to get a better signal would be to get an external wireless adaptor. I need to know what you are using and what kind of network you are logging onto.
This is just one site that shows how many choices you have. If you can determine what you need for a network adaptor then just google the words wireless adaptor or wireless network adaptor. As i said this is the only way i know to get a better signal.
Tip: N-network covers the largest area = best reception
Jan 13, 2009 | Toshiba Portege 2000 Notebook
Wireless internet
dont need to
mini pci cards or cardbus cards are expensive
any USB wireless adaptor will plug n play to your pc, more reliably than a card starting for ~$20
Jun 30, 2008 | Toshiba Satellite A135-S4527 Notebook
Problem connecting DLink modem into laptop
your network adaptor driver is not installed send your mail id i will send the driver for your mail
Mar 27, 2008 | HP Compaq Presario V6000T Notebook
Wireless Internet problem
did you reboot your wireless network at home?
Jan 03, 2008 | Toshiba Tecra A4 Notebook
Wireless cannot detect any network despite claims to be working fully
Try first dissabling the wired network adaptor, so as the pc is not looking for the wrong area connection. If you have used Windows to try to repair the connection the settings will be wrong for the router addreses. Go to your wireless network cards properties and make sure that on the internet protocol the obtain IP address automatically is selected. Run this flush:- Click Start>Run, then type ipconfig /flushdns then press enter. Re-start pc and type the routers address in your internet browser. Go to your router settings and ensure enable DHCP is set to automatically allocate ip addresses.
Jan 23, 2007 | Acer FerrariI 3400 Notebook
Internet access via bluetooth
I don't have a PDA, but I'm working much with Bluetooth in my Toshiba Notebook. So I found a interesting link from Toshiba about Bluetooth. Perhaps it helps you! http://aps.toshiba-tro.de/bluetooth/
Sep 08, 2005 | Toshiba e800 Pocket PC
BenQ Joybook 8000 Notebook Logo
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
