Question about Microwave Ovens
Samsung microwave mr5492w
Says start or keypad 3. hit either but nothing happens
MicrowaveSvc
  • 9098 Answers
SOURCE: ge microwave
To mrotu47182 and MaryGur - you may very well have different problems!
TO mrotu47182:
Chances are the magnetron overheated, blowing the "magnetron thermal cutout".
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
To MaryGur:
Your problem may be a bad keypad, but the first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If that doesn't fix it, you may have a bad keypad, assuming that your unit's display is on, but it won't respond to any key presses.
Is this your symptom?
If you'd rather have us fix it for you, we do that for $39.95 plus parts and you can visit us via our link here on Fixya http://tinyurl.com/yzjozk
Posted on Mar 18, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Sylnavia Microwave Oven
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If it still doesn't work, it may be a bad door switch or door switch mount.
One quick check is to gently hold down on the door while you press Start (or Cook).
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 27, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: samsung microwave
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Posted on Jul 04, 2008
  • 105 Answers
SOURCE: Sansui Microwave: Nothing Happens when you hit start
there is a safty door switch,if that switch is not making proper contact this thing happens.open the microwave look for safty switch and replace it or if you know how to open it then clean it and it should work
Posted on Aug 07, 2009
  • 4090 Answers
SOURCE: Microwave stops running after 2-3 seconds of cooktime.
The keypad has a fault. Obtain a replacement keyboard and install.
Please rate my help++++Thanks for using FIXYA
Posted on Jun 04, 2010
I have a Samsung model MR5492W microwave that burnt up in my RV which had a recall for this problem but I'm having trouble finding a replacement. Does anyone have any suggestions?
We have no way to look this up for you, it would likely be a custom made model oven for your application only and that is the problem. I would contact Samsung directly if I were you.
Nov 10, 2016 | Samsung Microwave Ovens
The start button stopped working. Everything else works on my MCD990B.
I think you are right on the money, the keypad control board is vital to the operation of the microwave oven, if the problem cannot be resolved it will require a complete replacement of the above mentioned part, unfortuneately cost should be considered.
Apr 14, 2012 | Magic Chef CHEF9 Microwave Oven
Stopped turning and heating
The problem is one or two bad door switches, "more than likely" the less likely is the keypad control board.
Apr 12, 2012 | Kenmore Microwave Ovens
I hit the start button on my Whirlpool microwave oven model no. MH7110XBB-5 but got nothing but a click. Any thoughts?
The control board that is located behind the keypad is the problem, I have seen the board develop bad solder connections around the relays. If you are handy with a soldering iron you can attempt a repair, remove top "2 to 6 screws" and remove keypad with control board attached "clipped or screwed in" remember to unplug microwave before you work on it.
Jun 28, 2011 | Whirlpool Microwave Ovens
I have a samsung microwave in our motorome. the power is on and I get the "Samsung 50 simple" indicator. However there is no response to the touchpad. The owner's manual says...
You have a bad keypad if you cant get it to respond at all.its also possible the door is not latched properly but usually the clock will set with the door open or closed so I doubt that is the issue
The display is actually saying "Samsung So Simple".
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 10, 2011 | Samsung Microwave Ovens
I have a Samsung microwave in our travel trailer, and all of the sudden, the keypad reads to press 6, but none of the keypad buttons are working, and the message keeps scrolling on the readout display. I...
This is a microprocessor problem in the appliance. It can often be reset by unplugging the device, waiting 10 minutes and plugging it in again. If that doesn't work, you will probably have to replace the appliance (cost to buy a new one in usually a lot less than trying to get it repaired).
Oct 10, 2017 | Samsung 1.8 Cu. Ft. Over-the-Range...
Jun 04, 2010 | GE JES1139BL / JES1139WL 1100 Watts...
Aug 07, 2009 | Microwave Ovens
Keypad Problems
Sometimes a keypad may not work because the door switches are faulty. When the door switches are working correctly it will allow the keypad to operate. They tell the microwave that the door is closed and the unit is dafe to use.
Many models have 3 door switches, it's wise to get all 3 replaced at once.
Mar 27, 2009 | Samsung Microwave Ovens
MY RV MICROWAVE DIED. I THEN WENT ON TO THE INTERNET AND FOUND THAT IT IS A RECALL. THE NUMBER IS #MR5492W. WHAT DO I DO TO GET A REPLACEMENT? I UNDERSTAND THAT IT IS FREE OF CHARGE. PLEASE REPLY TO ME AS...
CONTACT SAMSUNG SERVICE DIVISION HEADQUARTERS AT 800-932-3837.
Aug 15, 2008 | Samsung Microwave Ovens
Microwave Ovens Logo
408 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
