Question about LaCie (300950) 400 GB Hard Drive
Hard drive is "full" though I only have 186G on it
Highlighting the contents of the drive and checking "properties" I find 186G of files listed, which should mean I have plenty of room. However, if I just go to "my computer" and right-click on the drive and check properties, it is over 400G used and only 1G free. I very much doubt I have 400G of files, and I do have "show hidden files" activated. What is the problem? I have noticed earlier that when I have checked capacity it shows that there is only 1G or so free, even when I had less than 100G on the drive, but I could still add things so I didn't have a problem with that. Thoughts, solutions?
  • Jonathan Lutz Jul 05, 2007
    Solved problem immediately!! Wow! Guru!
    Problem Solver:
  • 12 Answers
I think that you have a partitioning table or formating problem on the hard drive. You can backup your information and format it to correct this error. WARNING: To format a hard drive means that all the information in the drive will be deleted. You should copy all the files that you want to keep in another drive before Formating your 400GB hard-drive. Windows Steps: -Go to "My Computer" -Right Click on the 400GB Drive -Click on Format... -Under Format Options: Check "Quick Format" -Press Start
Posted on Jul 05, 2007
    Novelist:
    Scholar:
  • 104 Answers
Here´s a thought! You can try running chkdsk cause maybe your freespace is being reported incorrectly! Open command prompt: Go to Start->Run then type cmd and press enter Run the chkdsk utility: where x is the drive letter of the removable drive at the prompt type chkdsk x: /f and press enter now windows will scan for filesystem errors and fix any if found. Also on another note, items in your recycle bin count towards the amount of used space! hope this helps regards, babb
I can't read/access my free agent contents
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
hop this helps
Nov 11, 2012 | Computers & Internet
After trying to restore with safety drill, nothing happened except when i went to my desktop, my maxtor drive isn't there any more and when I try to bring it up, I am told it isn't there. Where did my...
Hi, you said "when I try to bring it up, I am told it isn't there" so it sounds as if this is what Maxtor Manager is telling you. However you may find that the OneTouch drive does appear in Control Panel (found in My Computer). If so it means that the PC can 'see' it, even if Manager cannot. If the drive does not show in Control Panel there may be a USB power problem or something wrong with the USB cables. It is more likely that you can see it in Control Panel and possible that the Maxtor Manager program is corrupt, in which case you could try to repair it. You can do this by highlighting and clicking it in the list in Add or Remove Programs (in Control Panel). This should offer the 'repair' option which might do the trick. If it is still a problem, and if you saved the original contents of the OneTouch (as is strongly recommended in the installation guide), then you might consider uninstalling the Manager and re-installing it by clicking on the setup file in the contents you saved. Hope this helps but come back if still stuck. Regards Chas
Nov 27, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
Transfered contents to a terabyte drive weeks ago. Not recognized
thats a file system related problem, try to download this file systems repair tool, let see if work. download data recovery wizard tool from this link. http://www.easeus.com/disk-copy/download.htm
Apr 13, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
I can't delete files from my 160 GB Simpletech hard drive and it is full, what should I do?
Do a "disk cleanup"
Click on [My Computer]
Right-click on the External drive (D?)
Select [Properties]
In the [General] tab, click on [Disk Cleanup]
It will "scan" your drive, but not remove anything... alow it to complete the scan.
Look at the recommended list that appears and accept its findings.
This should remove non-essential files and leave your data intact.
Burn some of your data, especially video content to DVD (make at least two copies) ... then remove the data from your external hard drive.
You may want to purchase another (larger) external drive. You can use two of them or move your data to the new one.
Sep 30, 2009 | SimpleTech Signature Mini 160GB External...
A window appears saying "unable to scan. Be sure there is enough space in the destination disk."
Your hard drive may be getting full...
Or the account (user name) you are using on the computer does not have enough "rights" to create the output file.
Assuming it is Drive C:
Open [My Computer]
Right-click Drive C: (one time)
and select "Properties"
In the [General] tab, locate and click on [Disk Cleanup]
The system will harmlessly "scan" your hard drive to try to free up space. It is not deleting or compressing anything.
When the scan is complete, a list will appear, place a check on:
Tempoary files, Temporary Internet Files,
(do not "compress" any files)
and click [OK]
Try your scan again.
This is a temporary fix. You need more hard disk space.
Sep 28, 2009 | Canon CanoScan LiDE 600F Flatbed Scanner
Lacie USB 2.0 No files or folders displayed in backup folder
Did you try showing "hidden folders and files"?
In the Explorer, select the Tools menu, and pick Folder Options.
Select the View tab and in the list enable "show hidden files and folders".
You can also try showing system files (so choose not to hide them).
That should show you all files and folders on the disk.
Do make sure you are logged in as a user with admin rights.
May 13, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Undifined problem
You want to Check Disk for errors as soon as possible. If using Windows, right-click on the drive in My Computer, click on Properties, then the Tools tab, then the Check Now button, then the Start button.
This can happen with any drive if the connection to the drive is lost too soon after saving a file to it. Always use the little 'Safely Remove ...' icon for the drive first, before removing any flash drive.
When a file is saved, the data has to be written to available clusters, the directory has to be updated, and the cluster map has to be updated. In this case, it appears the directory was updated, but either the cluster map had not been updated so that the clusters were still available to be overwritten by a later file, and/or the data itself had not finished being saved, so the old contents of its clusters were still there.
Nov 07, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
LaCie (300950) 400 GB Hard Drive Logo
164 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
