Question about Pelikan PL-7055 G3 Wireless Controller for GameCube
Pl-7055 won't connect - Pelikan PL-7055 G3 Wireless Controller for GameCube
I have brother DCP 7055 it shows print unable 71 error pls suggest
This is due to Polygon Motor Error in the Laser Unit.
Pls try one of these:
1. Input the correction value of the laser unit correctly.
2. Check the harness connection of the laser unit. Try re-connect them.
3. Replace main PCB Assembly.
4. Replace the laser unit.
Mar 02, 2015 | Brother Dcp-7055 Laser Print Copy Scan...
Unable to print 36
Possible Reason:
1. High voltage power supply PCB
failure
---Replace the high voltage power supply
PCB ASSY.
2. Harness connection failure of high
---Check the harness connection of the high
voltage power supply PCB and reconnect
it.
3. Main PCB failure
---Replace the main PCB ASSY.
Aug 08, 2014 | Brother Dcp-7055 Laser Print Copy Scan...
Connecting the controller to the Gamecube
gamecubes dont have wireless controllers so it wont work unless its wired
Jan 22, 2014 | Pelikan PL-7055 G3 Wireless Controller for...
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
Dec 18, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
Driver
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jul 08, 2012 | Samsung PL 70 SL720 Digital Camera
MY BROTHER PRINTER DCP-7055 EORRER REPLACE TONER
This came from the Brother HelpDesk, yes they rang me and it worked.
Cover open Press Clear "Replace Drum?" (ignore this and quickly...) Press Start (blank screen, quickly...) Press Up arrows then switch to down arrow to 00 Press OK
Mar 09, 2012 | Office Equipment & Supplies
Brother dcp 7055 error-EF
brother dcp 7055 error-EF laser
Nov 22, 2011 | Office Equipment & Supplies
Connecting usb appears on my screen and wont download
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Apr 07, 2011 | Samsung PL 70 SL720 Digital Camera
Pelikan PL-7055 G3 Wireless Controller for GameCube  Logo
Top Pelikan Video Game Consoles & Games Experts
James Wishart
Are you a Pelikan Video Game Console and Game Expert? Answer questions, earn points and help others
