Just installed new wireless mouse. Do I need to reconnect some way?
SOURCE: Logitech wireless mouse and keyboard
Normal
0
Press the Receiver button (and the lights will start
flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT
button on the back of the board to connect the keyboard to the
receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button
on the back of the mouse to connect to the receiver. Then they
should work okay.
Hope this helps. Bud
SOURCE: Logitech cordless mouse problem
Normal
0
Turn the mouse over and find the small
rest/connect button on the bottom of the mouse and press it.
This should connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the button on
the mouse. This should be done whenever you change batteries or
glitch.
Hope this helps you. Bud
SOURCE: logitech cordless mouse and keyboard installation
You probably already done this but try pressing the receiver button and while it is flashing turn the board over and press the small reset/connect button on the bottom of the board and also the reset/connect button on the bottom of the mouse. It should work okay after that. here is hoping that helps. Bud
SOURCE: cordless keyboard not working.
there is a button under neath the recerver and the keyboard, hold the button under the recever and then hold the button under the keyboard
wait for a few secounds each time u hold this button then release and it should find it self then
SOURCE: Logitech wireless keyboard and mouse (ex 100) won't connect
use the secured keyboard connection you have to push a combination of keys then a 16 digit code but then your keyboard should work
