Question about Panasonic TCL42U25 42 in HD-Ready LCD TV
My panaconic lcd picture is pale - Panasonic TCL42U25 42 in HD-Ready LCD TV
I can't get picture. It just has pale colors.
You didn't give any information as to what the set is but if its a LED or LCD TV I would look towards the tcon board and its cables as being an issue
Nov 11, 2017 | Televison & Video
Panasonic Lumix TZ60 pictures are really pale on Ai+
Are there menu settings for picture quality ? Have you got exposure compensation set too high ? Is your white balance appropriate to the subject matter and lighting ?
Jun 15, 2016 | Cameras
Pictures are very pale
hi,
open cam sect, the iris unit must be changed.
Nov 21, 2015 | Samsung Digimax S600 Digital Camera
How do I adjust contrast
Check all pix sources first, Use Menu to put brightness to mid range, then contrast to 80-100%, if pix is still bad the problem is either main board or LCD panel
Oct 19, 2014 | LG Televison & Video
Vaio LCD problem
Periods.......Nice little items because they denote the End of a sentence.
See how this works?
"I have a vgn cs36gj, I was working with it, suddenly the LCD became pale black, I connected it to external monitor and it has a picture, sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
Now you try it.........
"I have a vgn cs36gj. I was working with it, suddenly the LCD became pale black.
I connected it to external monitor and it has a picture."
Okay, I got that part.........
"sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
WHICH LCD?
Laptop LCD?
External monitor LCD?
Man on the moon LCD?
1) If the external monitor LCD goes 'pale black', the problem is the graphics chipset.
This I do not believe
2) If the laptop LCD goes pale black, this I believe.
Post back in a Comment.
Regards,
joecoolvette
Apr 25, 2013 | Computers & Internet
LCD problem
Try cleaning the fan, vents and heatsink for starters. Has it been overheating? There are a few things you can check, Take a look at this video to help troubleshoot: http://www.youtube.com/watch?v=2Yi6GNFcP3w ALSO this: http://esupport.sony.com/perl/model-home.pl?mdl=VGNFS640_W AND: http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docTypeID=DT_KNOWLEDGEARTICLES_1_1&docType=kc&externalId=C270032
Apr 25, 2013 | Sony VAIO VGN-FS640W Notebook
The picture on my tv is completely dark, but the sound is working fine. how can i fix the picture? because it's a fairly new tv
Hello
Keep a close look to the screen, and see whether there is any trace of picture on it. If it is there, you can see pale shadow of it moving. If it is there, be sure that the backlight is not there. Thhere is an inverter board to energise the CCFL lamps used as backlight component. If the inverter board got faulty, the CCFL lamps won't light up, and no brightness will be there with LCD TVs. Check it. OK.
Oct 22, 2011 | RCA L26WD12 26 in. LCD TV
Color is pale
Reset colors,back to factory setting.Colors will be alot darker in ,can turn down colors after reset.
Jan 10, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Panasonic TCL42U25 42 in HD-Ready LCD TV Logo
18 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
