Question about Microwave Ovens
Set clock on lumina signature microwave oven - Microwave Ovens
5 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Setting clock on Westinghouse WST3501 microwave oven
Normally you would press Clock, enter the desired numbers, then hit Clock or Start. Try it with door open and with door closed.
Otherwise, contact Westinghouse Small Kitchen Appliances at 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 13, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave oven
On most Sharp models, you press Clock, then the digits for the time, then either Clock or Start.
You may have to open & close the door, then try it.
If you still need more help, please reply back or visit http://www.sharp.co.uk - they may have a user manual available for download.
Posted on Mar 30, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave stops after about 2 seconds, also have to reset the clock each time
TO mdambros
You have a bad magnetron. We see this over and over.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
You'll save a lot by taking it in yourself.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
TO guest (Panasonic oven)
The door switch you suspected is bad, and it must be replaced. They normally cannot be cleaned or burnished and be reliable.
See http://www.microwavedisplay.com/doorsw.txt
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
Posted on Jul 01, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Sanyo Micor/Oven/Grill EMG2553S Clock
You can download your owner's manual here.
Posted on Sep 01, 2008
How do I turn on the microwave and set the clock
well setting the clock comes first if my memory is right
Jan 14, 2016 | Microwave Ovens
I wish to change the time on the clock on my LUMINA MICROWAVE. I lost the manual so I don't know how to do it. Can you please give me some guidance on how to change the time? I look forward to hear...
I feel your pain, I am in the same position. After endless mucking around I finally figured it out. By the way, this is for my model P10034AP. Press these buttons: - Cancel [to abort anything currently underway] Clock [to set the time] Cancel [to clear the time allowing input] nnnn [the 4 numbers HH:MM in 24 hour time] Clock [to set the new time]
Hope that helps :) Cheers Jonathan Barton
Jun 29, 2011 | Microwave Ovens
How to set the clock in micro oven
hi shy..... the trick with most microwaves is that you must push the clock button first then set the time AND THEN push the clock button again to make it run. Joe
Thanks for choosing Fixya!
Dec 16, 2010 | Samsung MW1030WA Microwave Oven
I am unable to set my clock on the Magic Chef MCM1110 W/B Microwave Oven I just purchased following the Instruction Manual
Typically all you have to do to set the clock is to press the Clock button, enter the time, and press Clock again. However on some models, clock set is accessed through the main menu, by pressing the Help button and following the prompts.
Aug 17, 2010 | Magic Chef MCD1110ST Microwave Oven
Setting the clock
hello,
simple to fix up your self please follow this instruction below
  1. Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
  2. Step 2 Set the clock by pressing the "Clock" button.
  3. Step 3 Turning the dial on the sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
  4. Step 4 Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the sensor microwave oven.
  5. Step 5 When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
  6. Step 6 Press the "Start" button to allow the clock to begin on the sensor microwave oven.
thank you for using fixya.
Jul 31, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
How do I set the clock on a GE Spacemaker microwave oven?
You can get the manual here.
http://www.retrevo.com/s/GE-JVM1640SJ-Microwaves-review-manual/id/1080ci954/t/1-2/
But usually you just press the clock button to set
Good Luck and Please Rate Fixya!
Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
MW8107WA 1000 Watts How do I set the time? .
Cant find a manual, but on most microwaves, the clock is set by pressing the 'Clock' key, then the numbers for the time, and pressing the 'Clock' key again.
Jul 13, 2008 | Emerson MW8107WA Microwave Oven
Dec 10, 2007 | Westinghouse WST3504 Microwave Oven
Sharp R-9H56 Microwave convection oven
I have this model. Press clear then press Auto/Clock. Enter in the time eg 700 then press Auto/Clock again. The time should now be set
Jun 08, 2007 | Sharp R-1872 Convection/Microwave Oven
Microwave Ovens Logo
79 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
