Question about GE Spacemaker JVM1640SJ Microwave Oven
Turntable won't turn
Works just fine except when you turn it on the turntable will not turn and it makes a grinding sound. When I turn off the turntable no more grinding sound . Is it the coupler? And how do I get to it?
    Problem Solver:
  • 16 Answers
The turntable probably isn't on the spinny thing and that is what makes it turn- try lifting it up and putting it back on.
Posted on Jan 24, 2009
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
Ge spacemaker xl1400 model# jvm141obc Turntable still turns..but while making grinding sound Please help
My wife noticed a strong smell of something burning inside our home. Luckily we were home. The microwave was NOT on...and the turntable was turning and making that grinding sound. When I opened the door, the turntable kept turning....all digital lights were OFF. The microwave does not work. I am extremely angry that this unit was able to continue to grind unnoticed. If we were not home, I assure you that this would have caused a kitchen fire. The upper inside portion was extremely hot to the touch and the cabinet on top of the over-the-range microwave was also very hot. This would have easily caused ignition and a subsequent kitchen fire. I am going to report this to the UL.
Feb 10, 2011 | Microwave Ovens
Microwave turntable doesn't turn. Everything else
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can find links to helpful exploded view diagrams and part ordering help here.
But if you've recently had trouble with the cooktop lights, then the control board may be damaged.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Nov 28, 2009 | Frigidaire Microwave Ovens
Maytag Microwave 1150 Help
Check first the motor coupling under the turntable, if that is not the problem , then test and eventually replace the turntable motor.
Click here and select model to get parts and diagrams.
Apr 05, 2009 | Maytag MMV4205 Microwave Oven
Turntable does not rotate
Well it seems that there is some fault in the turnable motor, turntable system consists of the motor and coupler, turntable support with rollers and the tray.
I have a video link to help you more on this -- how a turntable motor should sound when you rotate it by hand... please follow the below link -
http://www.youtube.com/watch?v=rPSWi_z7M58
If motor grinding... etc., it means you may have a bad motor or plastic coupler.
Post further comments if you need more help....
Good Luck!!
Mar 14, 2009 | Microwave Ovens
Turntable sometimes works, mostly doesn't
It sounds like you have a jamming turntable motor.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 28, 2009 | Microwave Ovens
It appears that the noise is coming from the the turning or spin-
You probably have a bad motor.
Nov 20, 2008 | GE XL1800 1100 Watts Microwave Oven
Turntable sounds like its grinding
Sounds like the bottom bearing has siezed. This is then rotating on it's mountings instead of nice ball bearings.
Just check it's not simply any support wheels you can easily get to.
It is possible to access this from inside. If you wish to repair it, unplug, and remove case screws. The drive assembly is easily visable from underneath. If you can get the main bearing off, clean it in parafin or WD40 and use a little light oil on it.
Make sure you replace the case properly - with all screws before attempting to start again.
The microwave generator is only active when electricity is applied, and usually the door assembly is integral to the microwave chamber.
Jun 11, 2008 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
497 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
