Question about Sony STR-DE715 Receiver
Protect is on after a few seconds.
The outputs are ok.
  • 336 Answers
If the output are good, Check for a bad/loose ground. Check the solder near the input jacks, and tighten any and all ground screws that hold the circuit boards to the chassis. It could also be a bad transistor in the protection circuit.
Posted on Jan 22, 2009
Lincoln sp-150 idealarc will not arc any more ground output checked ok fuses checked ok incoming power 230v ok output term for + voltage to wire on spool nopower when trigger pressed.continuity from
There is a temperature activated switch near the transformer that will turn off control voltage until the transformer cools. There is also a fuse for the control voltage. That would explain why the motor won't run. There's a possibility that the trigger switch in the handle is bad too.
Oct 15, 2014 | Welding Tools
Repair
detailed and professional assistance 1 open tv by removing back cover. 2 check power supply output. 3 if not ok, 4 disconnect h/ output supply 5 repair power supply by checking components specially reg.output &asso.parts 6 it power output becomes ok. 7 check hori section(osc,driver&output)if not repair it. 8 connect h/output supply. check loose contact if any. put on the set.
Sep 16, 2007 | RCA F32450 32" TV
What is the output voltage output to the rebook Irun 14301
Pull the belt with your feet while voltage applied to motor. A motor brush may be stuck
Jun 08, 2014 | Reebok Exercise & Fitness
Picture ok sound through head phones only
Check the speaker/s. If the audio output by headphone is OK, and there is no audio output by the speaker; either the speaker or the audio output stage circuit will have the fault. Contact any service technician.
Gopakumar Gopalan Google
Mar 09, 2014 | Bush Televison & Video
Picture, but no sound
Hello
Check the speaker. If it is OK, check the voltage at the audio output section. If there is voltage, and still you do not get sound output, repalce the audio output IC. OK.
Mar 01, 2012 | Sony KDF-E60A20 60 in. LCD HDTV
No sound output from the tv to a sound bar.
Hello
Check its speaker or damage. If it is OK, check the audio output section. A commom fault to thie section is audio output IC damage. OK.
Feb 27, 2012 | Panasonic Televison & Video
NO VIDEO OUTPUT IN THE OUTPUT TAMINAL BAT Y SIGNAL OUT OK
hello,
check the RCA cable used to connect if it okay, if it okay, the problem will be from the printed circuit board..
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} tries websites like Shopjimmy.com,Ebay.com to buy parts or the function board for the replacement.
May 24, 2010 | Pioneer DV-270-S DVD Player
Attenuated output
Since you are able to view the output i'm assuming you are using an oscilloscope and only the positive or negative half of the sine wave is displayed. The output stage will be using a complimentry pair of output transistors, one amplifies the positve half cycle the other the negative. These are driven by a driver stage (phase splitter). One side is not amplifying. First measure the pos' and neg' LT supply rails. If ok check
ouput transistors with analog Ohm meter for base / emitter / collector continuity. If the amp uses an output IC and LT supplies are ok then use scope to view input signal, if input ok but output bad then IC is suspect. Since both channels are affected your problem is most likely a missing LT supply rail.
Mar 29, 2010 | Adcom GFA-5400 2-Channel Amplifier
Kenwood ks-122 in-dash car stereo/cd changer
hello chevi1981..what can happen is if whoever installed your system did not run your speaker wires properly eg if they have worn through and touching metal or a screw through the wires ,it can blow the audio ics in unit resulting in no sound.all these high powered units have above ground circuits in the audio stage .to check ,hook up a separate speaker direct to your unit,separate wiring ,if no sound, will most likely be the intergrated circuits..these will have to be changed by a tech as cd players are a beast to work on,also your 2 speaker wires should not touch one another.with your sec code if your have a removable face you may not have a code ,as removing face is your security .hope this helps
Jan 26, 2008 | Kenwood KDC-X717 CD Player
Tv set won't start up
as your reg. output is 40v & you have checked every possible things responsible for it. my suggetion is that first you isolate power supply from hor.section & see if power supply output is ok. if it is ok then check for short & leakage in h/output like 1 hor.output tr. 2 diode or cap in eht winding. 3 check for print near eht transformer. 4 disconnect yoke connector & check . 5 & finally eht or flyback transformer.
Sep 29, 2007 | Philips Magnavox 27MS343S 27" TV
192 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
