Question about Arrow T50P ARROW STAPLE GUN
Arrow Fastener Co./Electric Staple Gun - ETF50BN
I bought this item from Hechinger last April and have only used it half a dozen times. Last weekend when I was stretching a canvas, it suddenly stopped stapling. It clicks when the trigger is pulled but there is none of that explosive sound that accompanies a successful stapling. Can you help or can you suggest a repair shop in Greensboro, NC???
Thanks for considering this.
  • jappenzeller Feb 07, 2009
    I have the same issue. The brads still work, but the staples stopped working after about a dozen uses.
    Sergeant:
  • 359 Answers
First make sure no staple is jammed between the hammer and the anvil or plunger and you might also try to spay with pb blaster or wd 40 and pull yhe trigger several times very rapidly and see if this will free plunger , does work to free sometimes
Posted on Feb 07, 2009
How do I unjam my arrow electric staple gun
I have used a small screwdriver to pull out staples but occasionally had to disassemble to gain access - I think there may be just one screw to remove bottom piece
Nov 02, 2014 | Arrow Fastener ET2025D 3 In 1 Electric...
How do I load staples into my JT21 staple gun?
At the end of the stapler opposite where the staplers are driven out is a release.
Push it in and turn it and it should come out with a long spring
Load your staples, put the spring back and lock it.
Aug 31, 2011 | Arrow Fastener Co. Lt Duty Staple Gun -...
I have an Arrow JT-21M staple gun. How do I open it to add more staples?
there is no loading trya that pops out. the pusher arm is removable. when that is taken out you slid in the staples and replace the pusher with the locking tooth facing up.
http://www0.epinions.com/prices/Arrow_Fastener_PK21_Parts_Kit_for_JT21M_And_JT21CM_Staple_Gun_Tackers
Sep 03, 2010 | Dynamic Arrow Fastener Co. T50PBN Staple &...
Putting the nails inside the gun
Here is the manual http://www.arrowfastener.com/upload/manuals/79055020257_manual.pdf
Eric
Jan 24, 2010 | Staples Arrow T2025 Staple Gun For Flat &...
My jt21m stappler gun is not dispencing staples, i have loaded it the only way i can see how to, helppppp
Make sure you are using the correct staples for your staple gun. Same brand, proper size.
Next look carefully where the staple should come out as often there will be part of a staple caught up in that area which will have to be pulled out with a pair of pliers.
Oct 03, 2009 | Arrow Fastener Co. Lt Duty Staple Gun -...
My jt 21m stapler is jammed and i cant get it to open
At the end of the stapler opposite where the staplers are driven out is a release. Push it in and turn it should come out with a long spring.
Jun 26, 2009 | Arrow Fastener Co. Lt Duty Staple Gun -...
The door at the back of the staple gun won't close
You have too many staples in the gun. Chances are it was not shooting staples so you put more in. (Only holds 1 strip as if new from box) Check for a jam. Sometimes this keeps more staples from advancing. Please rate
Jun 05, 2009 | Arrow Fastener Co. Hd Staple Gun - T50
How do I load the brads into my Arrow T50PBN staple gun? Do not have a manual or paperwork.
Remove tail end bt pushing in,up,and pull out spring loader. Load up to 50 staple only!!
If loader will not go back in you have to may staples so remove some.
Please rate. Thanks jj505
Jan 08, 2009 | Dynamic Arrow Fastener Co. T50PBN Staple &...
Safety
Never let a youngster play with the staple guns. Even the manual ones eject staples with a great deal of force. If something is strong enough o enter solid wood, it is too dangerous for kids. Keep these locked up or in some safe place away from the kids. Keep the safety latch on at all times when you aren’t using it. This will prevent accidents but remember not all staple guns have this feature so you may want to look into finding one that does if you have children around. Of course, you don’t point the gun at anyone else and you keep your fingers out of the way of the staples. With a little common sense, stapling can be a fast, safe and simple way to do all kinds of repairs and projects around the house.
Aug 27, 2008 | Arrow FASTENER CO T50XP "NAIL SET...
Arrow T50P ARROW STAPLE GUN Logo
452 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
