Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
My sony wega lcd just shut down on me
I have a Sony 42inch wega LCD t.v. this morning a message came up on it but I could'nt catch it in time it said something about overheating and to check the fan to make sure it was'nt blocked and asked me if I wanted to switch to high elevaion mode but I could'nt switch it quick enough before it shut down and now it will onley turn on for a second or two the lighflashes on the power led for 3 bursts I pulled the panel off the right side of the t.v. and vacumed any dust that I could see. I bought this t.v. in 2006 if that helps. I looked at another sight and according to tecklore.com the 3 flashes means B+overvoltage protection [OVP] problem in power supply circuit T-603 and R672.
  • tanktruckdri Jan 25, 2009
    Yes this solution was helpfull, thank you leethdeuce for taking the time to read about my problem, althogh this is not a home repairable problem at least I won't be sending my T.V. in for repairs blind.
    Scholar:
  • 108 Answers
Http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF42WE655&content_id=68&category_id=11&problem_id=52
According to Sony, the three flashes indicate a lamp problem and you need to replace the lamp. Click this link and see if this info helps you out. Good luck !
Posted on Jan 22, 2009
  • 8,197 Answers
High temp warning
Make sure to remove dust from ventilation slots on the rear of the tv. In addition, make sure that there are no obstacles in front of the ventilation slots. If the message still appears after the dust is cleared call for service.
    President:
  • 1,952 Answers
Change the power board and power led bulb check you home electrical plug point in ur tv connection plug
  • mohammed marika thambi
    mohammed marika thambi Jan 22, 2009
    Look for a small flat chip attached to a heatsink marked like LA7838
    or something similar. Replace that chip. That may cure the problem.
    If not, I would suspect capacitors in the same circuit as being bad.
    But, start with the chip.
    Check the main power supply, specifically the regulator area. I don't
    have access to the service info on this set, so I can only provide
    generalities. The regulator might be a multipin IC such as STRSxxx or
    something similar attached to a heatsink.
  • 4,472 Answers
Yea definitely is overload protection. Your best bet is to have a professional service the television.
http://eservice.sony.com/webrma/web/index.do?SR=nav:service_support:electronics:repair:esup&ref=http%3A//www.sony.com/index.php
you can locate service at the above link. Also please take a moment to accept and rate our solution accordingly.
Thank you,
Lee
    President:
  • 1,990 Answers
Welcome to Fixya! That is Correct! The Power Supply is bad and will need to be Replaced.
  • Travis Humphries
    Travis Humphries Jan 22, 2009
    I would try and Locate an Authorized Service Center for this Repair if you are not Comfortable with Circuits and Soldering on it.
My 50" Sony Wega kdf50E2000
the lamp door cover is not secured properly or the lamp is not inserted correctly. Thats what the 3 blinks is indicating.
Aug 23, 2011 | Sony KDF-50E2000 50" HDTV
Sony 50A10 LCD tv. Turned on tv this morning and
Yeah the fans continue to rotate for at least 2 minutes past shut off time.
Nov 16, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony Wega Television - Sound and no picture
If this is a LCD projection then its time for a new lamp. Have your lamp placed.
Please leave comment:
thanks
Oct 06, 2009 | Sony KP-FX532M91 TV
Sony lcd projection tv kf50xbr800 shuts down and
Hey there, from what you are telling me I think the problem is coming from your Power Supply board it sounds like it could be two things
one: the board might have gone bad and its not sending the corresponding voltage to your components and that is why it keeps turning off
example: works ok for a while then gets weak truns off and then gathers enough turn back on
two: the power supply could be over heating and it has a sencor when it gets to hot to turn off this is very rear though
please rate this solution !!!
Jun 19, 2009 | Sony Grand WEGA KF50XBR800 50" Rear...
Yellow spot in lower right hand corner
You have pretty much narrowed it down to being a bad optical block. This isn;t good news, since the optical block is probably the most expensive part in the set. Your best bet is to contact Sony customer support to see if the will allow some kind of accommodation for the repairs. Sorry for the bad new; hope it doesn't effect the rating you give me for the solution. Thanks!
Nov 11, 2008 | Sony Grand WEGA KF-42SX300 42" LCD TV
Sony KF-WE50
my front panel sound is not working.......?
how i can do this.?
Jan 05, 2008 | Sony Grand WEGA KF-50WE620 Television
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
14 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
