Question about Maytag Dryers
LDG7500AAL wont stop - Maytag Dryers
My vue wont start and the battery is good and my alarm system wont stop beeping unless i disconnect the battery
My vue wont start and the battery is good and my alarm system wont stop...
get your car fix right now
Feb 28, 2016 | 2006 Saturn Vue
2007 sazuki forenzo windows wont stop
If you mean they wont stop accutating, you may a a bad switch, or maybe the switch got wet.
Apr 10, 2014 | 2007 Suzuki Forenza Sedan
Maytag gas dryer LDG7500AAL flame won't stay on longer than about 5 seconds.
The resistance is too weak in the hot surface ignitor to keep the gas valve open and requires replacement.
Dec 22, 2013 | Dryers
Maytag LDG7500AAL dryer ignitor lites up but burner will not lite
Their are 2 possibilities,based on exactly what is happeninh with your dryer.
1) If after the igniter came on,it stay on for 30 seconds to 1 minute and went off,but there was no flame as soon as the igniter went off? IF that is what your seening the coilds that open the gas valve are the problem. They are the 2 pod things on the top of the gas valve one of them has a plug with 2 wires on it,the other has a plug with 3 wires.IF no flame after the igniter went out those coils need to be replaced.
2) If the igniter came on and STAYED on and never went off within 1 minute?
for that since the igniter never turns off. The problem will be the flame switch. Its the black rectangle box mounted to the outside of the burner cone and has 2 wires attached to it.If the igniter did NOT go off the flame switch will be needed
The part numbers are,
GAS VALVE COILS 279834
FLAME SENSOR 338906
The parts could be purchased at your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
midwestapplianceparts.com
I hope i have been able to help you fix your dryer,
GENE
Aug 18, 2011 | Maytag Dryers
Model LDG7500AAL Belt installation Diagram?
Hi indsay12364...
Go to this webpage and you will see how to route your belt.
You will start out by putting the belt around the drum and then follow the picture.
Please take time to rate me
http://www.expertappliance.com/dryerbeltconfiguration.html
Jun 28, 2011 | Maytag Dryers
My miele wont wash it starts up then stops an wont drain out then the water intake light comes on
Hi If appliance fills then starts to wash then stops and starts. Then most likely cause is debris in circulation motor. This will require appliance and motor to be removed
May 21, 2010 | Miele 24 in. G643Vi Plus Built-In...
I have a Maytag dryer that has been moved several times and been in storage for about 7 years. We hooked it up yesterday and the ignitor won't come on. It is an older model LDG7500AAL from 1991. Where...
The ignitor on a gas dryer is very sensitive. rough handeling (moving) usually will dammage it. Clean the underside of the machine inside with a vaccum. Check if the ingitor is glowing when on and in a heat setting? if not replace. The burner has a flame sensor that looks like a small window in the burner housing be sure it is clean as well. CLEAN unit first then trouble shoot.
Sep 20, 2009 | Dryers
Tv wont stop changing channels
ok, Sony had this issue on their early production. The problem you are having is called a leaky switch. The volume down switch on the TV is leaky. To fix this you must replace the switch. This part is called the switch block. Part number 1-473-549-21
Average cost $26
Best regards
Circuitcity
Dec 18, 2006 | Sony KV-27V42 27" TV
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
