LG 21FU8RGE3AZ HAVING WIDTH & PIN PROBLEM
WIDTH IS MORE & EW ARE NOT NORMAL THROUGH SERVICE MODE
    Top Expert:
  • Televison & ... Master
  • 75,283 Answers
Check its pin-cushion output circuit part for the fault. Check and replace damaged component/s there. Download the service manual to this set by internet. It will have schematic diagram to your TV.
Posted on Jan 12, 2013
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
I have a Sylvania 6427 17
It sounds that the width of the picture to your TV is more than normal. There are two reasons for this fault. If the width adjustment data value in its service menu mode has been misaligned or the output DC voltage from the main power regulator is more than normal. You can determine which among the condition stated above is now effected to your TV
Just look at the picture. If the width and height of the picture is seem to be more than normal, make sure that the power regualtor section circuit has the fault. If the dimension of the picture is affected to its width only, [excess than normal] the data value with service mode should be checked.
Also note the position of the picture. If the picture position has moved so much than normal, ether towards left in this case, you have to adjust the picture position. Anyway, it will be best to contact any experienced service technician, since, service mode entry and data adjustment are skilled work.
Jul 31, 2012 | Sylvania 6427GG 27" TV
CRT Monitor width problem
replace flyback and yoke<br /><br />
Jan 15, 2010 | LG Studioworks 700S 17" CRT Monitor
What is the width of the tv
this is a pin-amp section problum .
if your tech. pls check sum spare in Pin -amp section .
pin-amp ic / capaciter / pre-set .
( i think your tv set screen is low width and up or down corner is bend ) if yes then replace capaciter 10uf/63v non poler or Pin IC
Oct 06, 2009 | Sony KV-27S20 27" TV
Ibm E54 monitor width problem
1.To replace TIP122 and it's related transisters (A733,C945) tracing TIP122 pins
2.Change Flyback caps
3.Open OSD select ZOOM Option and press 20 sec OPEN SERVICE MODE decrease the Width option &save it
4.Switch off the monitor
IF these solution was usefull pl appreciates rating
Nov 19, 2008 | IBM E54 15" CRT Monitor
Help for TCL Brand of tv
I WANT THE SERVICE MODE CODE FOR MODEL NO: DP21E101 TCL TV 21"
Jun 15, 2008 | LG 30FS1D TV
Monitor LG 500G
open osd menu and recall. if not solve the problem .the change in circuit .horizontal output stage tr dv32v.this problem is horizontal mode stage .change the transitor .and chk capecitor
Nov 18, 2007 | LG L1915S 19" LCD Monitor
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
