Will not spin
End of washing cyle Most water drains & spin commences but shuts down& tries to correct load & never gets to spin speed Will then step bach a process & commences to refill
    Sergeant:
  • 291 Answers
First unplug the machine.Check the drain hose between the tub and drain pump for debris. Some drain pumps have clean out basket attached to them. If yours does open it (prepare for water) and dump the debris then see if you can reach the impeller with a finger. Make sure it turns (it won't spin but you should be able to turn it with a finger) and is not wobbly or cocked to the side. There will likely be some debris in the hose from tub to pump remove it and shine a flashlight into the hose. Look in the tub to see if you can see the light. If so hose is clear. If not there may be a sock or something stopping water from draining properly. Once you are satisfied hose is clear and pump is functionable, plug the machine back in and give it a try. Good luck.
Posted on Jan 12, 2013
  • 641 Answers
SOURCE: Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Posted on Aug 31, 2007
SOURCE: Fisher & paykel top load washing machine
We had the same problem with our washing machine being full of water and beeping during the rinse cycle. The problem is that the filter, which is located under the washing machine, is plugged with something. Ours was plugged with a cotton swab. You have to tip the washing machine up and remove the filter and unplug it. The filter is in the center of the bottom of the machine. It twists off. I had to get the cotton swab out of inside the machine through this opening.
This machine plugs up a lot - I've never experience this with any other washing machine. Good Luck!
Posted on Nov 07, 2008
  • 713 Answers
SOURCE: won't drain in last cycle
Hi just read your posting.Now can you confirm the model number please.Please ;look underneath the machine to the front right and you should see a pump with a red or black fan attached.Turn this fan clockwise and anticlockwise a few times to hopefully loosen the pump if it is jammed.If the fan turns freely then put it back on its feet and start a spin cycle to see if it drains the water.Please reply with additional information on the questions and to tell me if you have the pump with the fan or if it is not draining or if it still is not draining.
Posted on Jul 08, 2010
blueextc3221
  • 15935 Answers
SOURCE: Frigidaire front loader washing machine won't spin...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Posted on Oct 01, 2010
Macmarkus
  • 2605 Answers
SOURCE: Frigidaire affinity front load. Starts
Welcome to FixYa.
Based on what you've described,...you likely need a door lock/switch assembly.
The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, aside from pump's being obstructed.
I think it fool's many people because the lock indicates it is energized on the panel, however the built in "monitor" switch inside the assembly fail's. I do see a lot of these particular machine's...unfortunately.
You should be able to purchase one at most local brick & mortar stores or on-line part's depot's such as "searspartsdirect.com" "repairclininc.com" to name a couple. They usually sell for about $50 or so, part # 1531974 ( # at repairclinic.com ) and are relatively easy to replace. It should resemble the image here...
As for replacing said switch, There are a couple ways to access it, through the top and squeezing your arm down the front or the way I prefer, remove the front bellows spring/retainer.
1) **unplug the washer from the wall...safety first of course.**
2) Remove the spring, get it started where the spring is located with a small screwdriver. Once you`ve got the spring/retainer off ( it comes off and on pretty easy by hand ) pull the gasket/bellows back away from the cabinet.
3) Undo the two screws holding the switch to the cabinet, pull the switch out ( there is just enough slack in the wires so don`t pull too hard ) and swap the wires from the old assembly to the new one and you`re in business.
4) To put it back together, just reverse the removal procedure. The trickiest part is the retainer. Rap the retainer around the boot leaving the spring for the last...and make sure the spring is located at the 6 o`clock position...usually. Just wherever it was initially.
Let me know if you need further assistance going forward or if my instructions are not clear.
P.S.
There is a slim chance of a faulty motor or motor control board, but that would not be where I would direct you to start...those are exceptions rather than the rule.
Thank you for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Posted on Dec 12, 2010
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Washer won't go into spin cycle, stops after final rinse. When I try drain &rinse it still will not spin.
If the unit does not spin correctly, this is usually an indication that the unit can also not drain. The unit will not spin if it senses a blockage or issue with the drain lines and/or pump. Try to check the drain lines in the back of the unit for any issue, and then see if you have an access panel to get to the coin trap or drain pump itself. Often socks and debris will clog up in this area and cause your problems.
Dec 25, 2012 | Frigidaire ATF6000ES Front Load Washer
Spin cyle does not come ,but water drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Maytag PYE2300AY Electric Dryer
Brand new. Load gets stuck on 14 minutes or some other time & repeats over & over. Wont finish cycle. We have to use the drain & spin to get the water out but then clothes are not rinsed well....
Sounds like you are probably doing a very bulky or real off balance load on a high spin speed setting. The washer is trying to get the load up to spin speed, but the load is too off balanced. Try the lowest spin speed setting for that load. If it makes it through that, then power machine back on and just push the spin speed button until the next higher speed shows up, and then the start button if you want to spin it out better. If it still didn't make it through the original cycle on the lowest spin speed, your load must be way too off balanced, like one coat that is saturated with water. If that is the case, you may even have to squeeze some water out of it by hand before you would be able to get the washer to get it up to spin speed.
Mar 21, 2010 | LG WM2487H Front Load Washer
Spin cyle
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Hope it may help you;
Regards,
VOTIT
Sep 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Machine will not agitate for wash or rinse cylces
that could be your problem or your drain pump maybe full... try spin and drain see if it will drain
Sep 08, 2008 | GE Energy Star WCVH6260F Front Load Washer
Won't spin
As previously suggested, try cleaning out the drain system. See my solution at http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Nov 25, 2006 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
