Question about Whirlpool MH1140XM Microwave Oven
Rust forming between the glass panels in the door
Whirlpool microwave...getting worse and worse. Is there a way to correct or will door have to be replaced? Is replacing door something I can do? Thank you!!
  • rmarkle243 Jan 22, 2009
    Thank you so much!!! I will give this a try....seems like it is easy enough!! Thank you again!!!!
    Novelist:
  • 140 Answers
Actually if you can use a screwdriver you can fix this problem yourself. The glass can be accessed by taking off the screws holding the inside panel to the door on. The screws are visible. Once this panel is off you will see the screws that hold the plate glass in. Keep in mind that the gasket that goes around the glass and inside the door panel are there to keep microwaves from escaping. So in all this be sure to put it back in place right. I have fixed many doors and there really is nothing to mess up. Just put it back together the same way you took it off but in reverse of course. As far as cleaning the glass there is a product call Goof Off that comes in a spray. They sell it at Lowes or Home Depot either one. Use steel wool that you can get there as well and spray a generous amount on the steel wool until it drips slightly and not on the glass directly. Clean all the areas and kinda of use a dry rag to wipe off any excess. After you've taken care of the rust stains and are satisfied take a good glass cleaner like Windex and clean it like regular glass. Keep in mind that the whole door will come off and completely apart to get to both glasses and in between. I would comment additionally that what is in between the glass may be that way due to a leak through the gasket around between the inside and outside glass. However, inspect the gasket well and if you need to you can find a replacement through the dealer or manufacturer of that brand. Keep in mind also that leakage from the microwave door in any way could hurt someone with a heart pacemaker if they get close or someone else that has a battery in it such as people with embedded health units for muscles spasms after back surgeries and the like. Those are the most critical health issues to consider and to be sure that your gaskets are good.
Posted on Jan 22, 2009
On whirlpool microwave mh6141xkq-1. How does one clean between the glasses? Do you have to take off the microwave door? Thanks Martin Vacca
Martin,
Coming from someone that has dismantled many different microwaves, taking apart a door from your microwave would not be an easy task. There are usually many small plastic tabs that hold different components of the door together and usually several of those will break off when trying to take the door apart. The door is also designed to keep the microwave radiation from coming out the front and if you did not get it put back together correctly, you could expose yourself to that radiation. If it is a problem for you to have the glass dirty, I would recommend taking it to someone professional to have the door taken apart so that they can check afterward to make sure there is no radiation leakage. Hope this helps!
Aug 02, 2015 | Whirlpool Microwave Ovens
How do you remove Whirlpool microwave mh7140x door to replace white plastic door face?
If you are referring to the disassembly and replacement of the door, just follow these steps:
1. Open the door all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
2. On MOST microwave ovens, all you have to do is remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel to release the clips that hold it in place so you can pry the plastic up. Work your way slowly around the perimeter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful RF radiation.
3. With the inner panel removed, locate the door handle screws and remove with a screwdriver.
4. The panel glass should be "sandwiched" in place (double layer on most ovens) and should either lift out, or have retaining clips holding in place. Remove and set aside.
5. The remaining piece(s) comprise the door frame. Replace as necessary.
REASSEMBLY: Re-insert the panel glass, followed by the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
There are several parts sources available that you can use to purchase replacement parts:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also offer helpful exploded view parts listings to aid in parts identification and location. Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this advice is helpful.
Nov 03, 2010 | Whirlpool MH7140XF Microwave Oven
Own Whirlpool Microwave oven Model MH6141XKQ. How does one clean the "inside" glass of the door. By inside, I mean between the two glasses on the door.
You will need to remove the door and take the door apart to clean between the glass. This process is not that difficult. Just follow these steps:
1. Open the door all the way and lift straight up at the hinges to remove from oven.
2. Place the door, face down on a soft surface to protect the door and glass. A layer of towels on a countertop or table is recommended.
3. Remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel. Work your way slowly around the perimeter of the glass to release the clips that hold it in place so you can pry the plastic up and pop the panel loose. Use care not to pry against the glass.
4. With the inner panel removed, the glass should be easily accessible and can be carefully lifted out and cleaned. Clean with a good non-streaking glass cleaner.
Make sure you remember how the door is assembled as you take it apart. If you forget, the following webistes have illustrated parts listings to show how your door is assembled:
If you have any questions, please post back and let me know. I hope this helps you.
Aug 12, 2010 | Whirlpool Microwave Ovens
There is a whirlpool Microwave (model:MH1150XMB4) in our apartment. Unfortunately, there is a crack in the door. Although the crack is only in the plastic frame of the door, the landlord asked us to...
Got the same problem. Still inquiring but I might have found a solution here : http://midwestapplianceparts.com/microwave-parts-537/whirlpool-microwave-parts-648/microwave-door-panel-663/whirlpool-microwave-door-panel-w-glass-4212.html
$79 for the panel only
Jul 01, 2010 | Whirlpool MH1150XMQ Microwave Oven
I have rust like streaks inside my Whirlpool Microwave Door Panel. It is unsigthly. How do I get rid of the rust-like streaks?
Disassembling the door is a major pain and the streaks will likely only be faded not removed completely. Best solution is replace the door. Otherwise taking it apart(and not damaging it) is your only option.
Eric
May 19, 2010 | Whirlpool MH1140XM Microwave Oven
Ge jvm1542bf001 has rust discoloration on glass part of door. Took door off, removed handle. Is there a way to access the inner surface to rid grid of rust?
It would appear that no one knows how tofix this problem. I have the same problem and the only sugestions I get is to replace the door.
Jan 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing a whirlpool microwave door handle! got the new handle..how do I open the door up to screw the new handle on?
To replace the door handle you need to access the door handle screws. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. This can be easily be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful RF radiation.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
You can view an exploded view diagram of your microwave at pcappliancerepair.com for reference. Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Nov 24, 2009 | Whirlpool MH7140XF Microwave Oven
Mh6140xkb door glass has rust and stains
If there are letters and numbers after the model you listed the parts are here. http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=mh3184
Jul 11, 2009 | Whirlpool MH3184XP Microwave Oven
How to replace the door handle on a mod. MH 1170XSY-0 mico wave
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Jul 09, 2009 | Whirlpool MH1170XS Microwave Oven
Cleaning inside of microwave door
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 11, 2009 | Microwave Ovens
Whirlpool MH1140XM Microwave Oven Logo
826 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
