Question about GE Profile WPRE6150K Top Load Washer
Wpre6150k does not agitate
Does not spin
Ge profile wpre6150 repairs
Remove the top cap on the agitator and re-tighten the nut.
May 07, 2015 | GE Profile WPRE6150K Top Load Washer
Know when clutch going bad
Needs agitator dogs in agitator.
Mar 13, 2014 | Whirlpool Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
I have a Kenmore washer model 110.26832690 that will not spin. It will fill up, agitate, but on spin cycle it will only drain. Does this sound like a bad lid switch or a bad drive adapter? From what I've...
if it agitates correctly,then its likely your lid safety switch, agitate and spin cycles are reversed by the motor during the cycles of agitate and spin,some units are wired to not operate on either agitate or spin,but some will operate on agitate with the lid open,but not on spin,open control panel and bypass the lid switch and this will tell you before you tear out the direct drive pump,motor and get to the d.d. coupler at the transmission
Mar 20, 2011 | Kenmore Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Agitator doesn't agitate. Fills, spins and drains
Unfortunately, that sounds like a transmission issue. Power is getting to the trans, or it wouldn't spin, but the other part of the trans that causes agitation is broken.
Nov 15, 2009 | Washing Machines
Brand new GE Profile leaves clothes soaking wet
It is under warrenty call the store where you bought it and have them look at it. If you mess with it it will void your warrenty, belt may not be working or transmisson may not be shifting. The house call will be at no charge.
Sep 10, 2009 | GE Profile WPRE6150KWT Colossal Capacity...
Agitator doesn't spin during wash cycle
If The washer won't agitate
Check to make sure no clothing got wrapped around the agitator. Check the lid switch, timer, and drive belt, other potential causes, such as a bad transmission or bad agitate/spin solenoid, but they are much more involved.
if the washer won't spin, the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here as well. Sometimes if the load is unbalanced or too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
Here are the steps to replace the agitator.
1: Take the fabric softener dispenser off and pry off the agitator lid.
2: Use a socket wrench with an extension bar to remove the stud and seal.
3: Remove the agitator top and bottom.
4: Check the agitator clutch assembly (located in the agitator top) for excessive wear.
5: To replace, just reverse the directions.
Jun 29, 2009 | Washing Machines
Agitator free spins
Remove the top cap on the agitator and see if the bolt has come loose. If it is not there, the agitator will come loose from the gear case shaft and free spin.
Mar 21, 2009 | Frigidaire FWS833A Top Load Washer
Spin cycle with agitation motion occurring simultaneously
Hi again,
Appreciate the "Ask Me".
I believe the dampness is due to slow spin speed as you also have concluded. And I suspect that partial winding of the motor is the culprit. Hence, replacement is in order.
As to your concern why the agitator also operate during the spin setting, it could possibly be stuck or locked agitator dogs. Agitator dogs function is better explained here by another FixYa member, jsrock516.
Cheers.
Jul 25, 2008 | Washing Machines
GE Profile WPRE6150K Top Load Washer Logo
22 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
