I need a Cannon sp3 ignition cooktop manual - Computers & Internet
How do I replace the jgp636 igniter switch?
How do I lite a whirlpool electric gas stove?
Dec 31, 2012 | GE Profile JGP636 Gas Cooktop
ELECTRONIG IGNITION DOES NOT WORK TO IGNITE THE COOKTOP I HAVE TO USE MATCHES TO IGNITE THE GAS
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Apr 04, 2011 | Bosch 30 in. NGP74 Gas Cooktop
All ignitors not igniting on model # sgsx365cs, 5 burner cooktop.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jul 19, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
Profile JGP636 Gas Cooktop: my ignition for the gas cooktop is not clicking...
heatman101
May 17, 2010 | GE Profile JGP636 Gas Cooktop
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
Constant sparking
I don't have a Thermador cooktop but here is ma taught.
Could you unplug the two faulty igniters and see if problem remained
Could you plug one of the faulty igniter at the location of a good one. The goal is to isolate the problem. Is it the igniter or the electronic board.
Faulty ground problem may occur also after an spillover on the stove. In that case, use a cotton swab dipped in scrubbing alcool and clean the spark area on the igniter and the burner.
Good luck
Mar 31, 2017 | KitchenAid 31 in. KGCC505 Gas Cooktop
Kitchenaid gas ccoktop electronic ignition continues to click
We called in an appliance repair technician. He said during the cleaning process of the cooktop, when the control knobs had been removed to thoroughly clean the cooktop, some cleaning fluid or water or moisture got into the ignition switch panel under the cooktop. Letting it dry for 24 hours should fix the problem and this appears to have done that.
Feb 17, 2009 | Cooktops
Auto electric lighter for the gas stove no longer works
gud day,the problem is ur igniter ligther is totally damage & nid to replace, if u want to use ur cooktop use matches or ligther every time open ur gas cooktop,tnx gerbee
Nov 17, 2008 | Gaggenau 23 in. KG 260 Gas Cooktop
Ge 36
You may need to consult near you an electrial engineer this couild be happened you need to design all parts of igniton line / many thing to change replace the switch knobs iugniter tips terminals and wirings also high voltage igniter coil. so many thing thing to buy.
Jan 07, 2008 | GE 36 in. Profile JGP963 Stainless Steel...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
