Question about Miele S514 Solaris Electro Plus Vacuum
How do i open the miele vacuum to get at the electronics?
Have a miele black diamond and cannot figure how to get the 2 shells apart.
  • mcflavin Jan 24, 2009
    I'm stuck on this as well. Have you found a solution? I've removed 5 screws so far but I think I have to get the switch plate (by that I mean the place where the on/off and cord retract switches are) off to find another screw.
3 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Miele Solaris height adjuster arm won't snap back in
Maybe this picture will help, put the pieces together, then it sits directly under where #230 in the pic.
Posted on Mar 29, 2008
futureloginn
  • 734 Answers
SOURCE: Miele Solarus Canister Vacuum stopped working
Miele S251i Plus Bagged Canister VacuumMiele white star canister vacuum - won't turn on,...
I have the above canister vac, which after my son tried to vac the stairs, it rolled down the stairs on him, but still worked, after turned off/on. Then after turned off maybe 10-15 mins., stopped working when we tried the switch. My father in law is our fix it guy, but still having a problem with the switch. Is there a wiring guide we could look at?
Thank you!
ALevy
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can try to call the factory for the Miele S251i schematics / wiring diagram @ the phone number and website listed below or I put a few pieces of information listed below that might help.
1. The vacuum cleaner switches off automatically
A temperature limiter switches the vacuum cleaner off automatically if it gets too hot. Some models have a warning light (triangle) which comes on to indicate that it has overheated. Allow the appliance to cool down for approx. 30 mins. and remove any blockages to the air path.
2. The "Change dustbag" indicator stays on even when a new bag has been inserted
To ensure the dustbag change indicator gives a correct reading, lift the floor nozzle or power head off the floor slightly to prevent the vacuum created in the suction tube from influencing the reading.
3. The exhaust filter indicator is red
Change the exhaust filter and then press "Reset" to switch off the indicator light.
http://miele.com 1-800-999-1360 Customer Care
Toll-Free Contact Information
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
www.AVACcorp.com 1-800-328-9430
Posted on Dec 02, 2008
  • 52 Answers
SOURCE: Opening Miele S28i Vacuum cleaner
If it is similiar to the white star you may find the instructions here useful: http://www.sannerud.com/house/miele.html
hope so
Posted on Aug 19, 2010
My Miele upright vacuum will not start. The red light will come on but not the motor. Why is that?
I believe you should have an amber light, if you are seeing a red light located above the bag compartment door, that indicates a fault with either the electronic module or the motor. Unless you have a voltage meter and are familiar with pulling plastic tabbed appliances apart, I suggest you email http://www.mieleusa.com/emailtomiele/emailus.asp?nav=&snav=&tnav=&oT=66 or call direct. Residential Appliances or Vacuum Cleaners(800) 843-7231Monday-Friday:8:30 am - 5:00 pm ESTSaturday-Sunday:Closed
Mar 04, 2013 | Miele S7210 Bagged Upright Vacuum
How can I put together miele vacuum lid 2 black peices came out
see the instruction manual and proceed according. If you do not have call or login in Miele Vacuum and request your question.
God bless you
May 16, 2012 | Miele Carina Vacuum Vacuum
Hi a curve piece of wire or metal fell out of the handle when taking it apart.Can`t figure out where it goes?
If it is about 2" long , it is the snap ring almost right at the end in the narrowest part which keeps the extension tube in place .
If it is about 7" long , It is the antistatic strip which sandwiches between the 2 halves of the handle underneath.
Hope this helps.
Jan 03, 2011 | Miele S514 Solaris Electro Plus Vacuum
Miele s251i vacuum plus-red light indicator is on. Motor on, not spinning. Help!
you will need to take the unit apart find the screws that hold the unit together 2 under the the bin cover at the hinges 1 holding the black control cover when you have removed the screw then just lift the cover it will be stiff just pull it up under this find all the screws and remove them remove the motor and you will see the pcb on the side of the motor it will have a dry joint on the solder this back up and that should do it make sure you unplug the unit b4 you work on it
Oct 25, 2009 | Miele CatAndDog700 Bagged Canister Vacuum
Hi The catch on my miele revolution has come off
Hi Sally If you download the manual this will be easier to explain:
http://www.miele.co.uk/Resources/OperatingInstructions/S%20556%20S%20558%20S%20658.pdf
If you look at page 22 you'll see the optional blower attachment and how to install it - ignore this - however it gives you the view of the two hinges on the actual accessory door. These clip on at either side of the front but there should also be a square partition on the back of the accessory door. Here is where the clip sits into the door and the parts hook onto two spring holders at the bottom. Once that is fitted the door should then go onto the front.
Jul 17, 2009 | Vacuums
Meile SEB 213 powerbrush cuts out
Your problem is either in the wand, assuming you have the telescopic dark grey electric wand. The only other thing it could be is the hose, once again, assuming you have the electric hose with either the rocker switch that shuts down the power brush, or the deluxe hose, with the electronic suction control, as well as the brush shut off. Miele wands and hoses are notorious for causing power brushes to cut off. If your Miele is under two years old, I would suggest taking it to a autherized Miele service center, and see what, if any, warranty you have left, and have it checked out. Let me know how you make out.
Jan 14, 2009 | Miele SEB 213-2 Vacuum
hope so
Jan 10, 2009 | Miele S251i Plus Bagged Canister Vacuum
How do I take my Miele S251i apart to be able to chenge the powercord?
HOW TO OPEN MIELE 251 VACCUUM: 1-Unplug from wall and disconnect power cord 2-Remove black switch panel at back of top panel: A-Use Phillips screwdriver, remove two silver screws visible between back of hinged top door and front of black switch panel
B-Push back of the panel down while pushing it forward (towards front of machine). There are two plastic notches and clips which are tightly fit together that you need to separate.
Once it releases, push it a bit more towards the front of the machine and lift off panel. It has wires connecting it to the main body so it will not remove completely.
C-Be careful not to lose the springs that simply sit inside of two plastic channels, one under each of the two switches. These are required for your witches to operate properly.
3-Locate screw at bottom of deep rectangular hole now revealed (under former location of black switch panels). Unscrew using Phillips screwdriver. 4-Open hinged top panel. Locate two silver screws, one on each side of main housing. Unscrew using Phillips screwdriver. 5-This will let you lift off the whole top assembly, door and main housing, revealing the plastic chassis and the motor unit within.
You now have access to the motor, wiring connector harnesses, circuit board and the cord reel.
Sep 13, 2008 | Miele S251i Plus Bagged Canister Vacuum
Mar 25, 2008 | Miele S514 Solaris Turbo Plus Vacuum
Miele S514 Solaris Electro Plus Vacuum Logo
438 people viewed this question
Top Miele Vacuums Experts
Roger Potts
Mack Baxter
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
