Home | Toshiba | 43H71 43 in. Rear Projection Television | Red is out of focus
Toshiba 43H71 43 in. Rear Projection Television
Problem for Toshiba 43H71 43 in. Rear Projection Television
Red is out of focus
By gleasonrh on Jan 22, 2009
Turned on tv this morning and noticed that the color red is not lined up. Tried auto focus, no luck. What to do? Thanks.
Same Problem
Apr 05, 2009
-   I have the same problem. Out of nowhere i turned on the tv and red is way out of focus, touch focus doesn't do anything but report error. Did you ever fix yours?-   christoph936
Solution #1
posted on Jan 22, 2009
Not Rated)
Slinteriors
Rank: Guru  Toshiba Televisions & Videos  Expert
Rating: 89%, 3665 votes
the 50h81 convergence kit will work for your model
you can get the kit at the fllowing link with free instructions. heres the link.
http://servicemanuals.vstore.ca/
Was this helpful?
Yes
No
Popular Solutions for Toshiba 43H71 43 in. Rear
Questions and Unsolved Problems for Toshiba 43H71 43 in. Rear
Do you recommend Toshiba 43H71 43 in. Rear Projection Television?
Answer
Answer
the picture is messed up- the colors are separate and shadow-like.
Answer
tv will turn on but have no picture. the power light does not flash just stays constant
Answer
Toshiba flat panel model #PDP42X3 shows no picture but has static sound is it fuses? How do I know... (More)
Answer
toshiba tp61f90 no picture when i hook up cable to either tv video 1 or 2 standard cable jack. if i... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba 43H71 43 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
