Question about Sharp AL-1642CS Copier
Sharp AL-1642CS The printed pages all have a dirty (Black) edge (can be wiped off, but this a pain)
  • seattlerust Feb 01, 2009
    Similar problem plus when I look inside around the cartridges, I find little piles of toner powder near the transfer charger and the drum cartridge. Does this mean that I have a failed cartridge? Now replacement lights are on and my copy count is still less than 1000.
    seattlerust seattlerust@gmail.com
    President:
  • Sharp Master
  • 990 Answers
Hello sir; I believe that's drum cartridge problem try to change that see what going to happen.
Posted on Apr 23, 2009
How ot fix H4 error on a sharp AL-1642CS
c-photo-c-photo press 14 press print key
Jul 11, 2014 | Sharp AL-1642CS Copier
I have the sharp al-1642CS and need to print ups full sheet labels for shipping. Tray 1 will not pick up the labels and jams. I can not get the sharp to print via the multi-tray when I send a job from my...
Will the tray not pick them up at all, or do they feed out about 2 inches? If they feed out of the tray and will not get past the curved area you need to open that door where the jam is and make the spring pressure on those springs on each side tighter. I kind of loop the bottom hook of the spring up into the rest of the spring to create more spring pressure on the rolls and then it should work.
May 19, 2010 | Sharp AL-1642CS Copier
I have a Sharp AL 1642 CS. It prints black copies. It came out of no where so I know it isnt dust on the lens. Even after adjusting brightness settings it prints pitch black pages. The bulb on the scanner...
Problem on three things.
1.OPC drum cleaning blade is very old,so lost her activities.
2. Laser unite very dirty,so you need clean.
3. setup or configure exposure control.
# Press Auto key three second
when exposure light indicate now position,select way lighter side.
Jan 20, 2010 | Sharp AL-1642CS Copier
Sharp AL-1631 Copies has begun to print verticle lines on page.
if the drum already been scratched out,so there is no solution to repair it,u have to change the drum.before change the drum check the copier glass surface if any dry up material,wipe it with dry cloth.
Dec 09, 2008 | Sharp AR-5320 Black and White Copier
Printing problem on Sharp Copier Al 1642CS
it would have spilled toner on the laser unit glass which can be accessed after removing the developer & drum units. Its on the upper part inside the machine in the drum chamber.
Nov 28, 2008 | Sharp AL-1642CS Copier
AL-1642CS
try to clean the cover glass at the top of the copier with alchol.
be sure that ther is no any dot or lines on top of the glass specialy the right side.ok
Apr 16, 2008 | Sharp AL-1642CS Copier
"Scanning in progress" reported even when I'm not scanning anything
You need to install the print driver and Sharpdesk before you connect the USB cable.
Dec 10, 2007 | Sharp AL-1642CS Copier
106 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
