I had to change internet provider, so I had to get a different modem. The router stoped working, so I tried the setup disk the came with the router. I hooked it up like it said exept is says to connect the modem to the router with blue cable (I don't have). I used a regular ethernet cable instead and don't know if that could be a problem.
The problem is I go through the setup wizard and try to save my settings it wont let me. It says "The setup utility was unable to locate a wireless-g broadband router on your network. Please make sure your wireless-g broadband router is powered on and all cables are properly connected." It all hooked up right and the lights are on.
Any old ethernet cable should be fine. The setup disc is generally used only for initial setup to establish communications between router and pc, and to also configure your internet providers settings. You can access your router from your pc by going to http://192.168.1.1 and you can change settings in the router from there instead of using setup disc. If you insist on using the setup wizard disc you usually have to set your computer's ip address to a specific number and possibly reset router to default state (see manual or http://www.linksys.com).
Comments:
Jan 22, 2009
- Since you already had a working setup, if you just replaced the modem and leave cabling as it was before when it was working, you should be able to just go in through your browser into the control panel of the router and change the particulars for your new internet provider (user name, password, etc...).
Was this helpful?
Yes
No
Popular Solutions for Linksys Wireless-G WKUSB54GS
I have a belkin N F5D8233-4v3 router with the latest software and I recently bought a black armor...
(More)
I have a belkin N F5D8233-4v3 router with the latest software and I recently bought a black armor NAS 110 network storage and the NAS 110 cant pull an ip from the router when it is connected.
i hv a DIR-655 router & i've lost my manual. i want to secure my router and lock out others...
(More)
i hv a DIR-655 router & i've lost my manual. i want to secure my router and lock out others outside my residence. can you take me thru the steps?
My opera browser gives a download speed of 95kbytes/sec on 512kilobits/sec, can I get it more by...
(More)
My opera browser gives a download speed of 95kbytes/sec on 512kilobits/sec, can I get it more by Port Forwarding router??
