Question about Kitchen Ranges
Restoring Locke Stove mod 120,need blowup of interior parts assy.
I need a picture of the interior buildup of a Locke Stove model 120.
Grilling bulb out
hello chris microwave is an american model
I found the tube/bulb you looking for is like the picture and called quartz grill tube and can be replace by similar voltage 120 v
Apr 01, 2014 | Whirlpool GH6177XPS Microwave Oven
Hamilton Beach 31197 blower not working
There is no fuse. This is not an easy repair. I replaced mine which had an open winding. HB tried to make this unit so it could NOT be repaired, but of course it can be if you want to spend the time. The motor is part of a metal duct assy which also holds the rotisserie motor. It is RIVETED to the interior wall of the oven. The fan motor is a DUAL shaft C-Frame shaded pole 120 VAC ~ 3000 RPM ~ .5 amp motor which is not very common. The thermo on all these units is also inaccurate as the "sensor" is simply a metal plate screwed to the top right area of the oven interior. When I replaced my fan I also put in a new REAL oven thermo with a 12" sensing bulb which I mounted inside the oven as it should be. It took some searching to find these two parts. I have all the instructions and can post images if you want to tackle this. I did because the oven is large and the replacement model (31100 for $69 at Wal-Mart) has 1.5" less height and it uses the SAME parts with the same design flaw for the thermo. The retail cost on the parts for this job are ~$160, but I got mine for $15 total. I paid $48 for this oven years ago at Sams.
Apr 14, 2012 | Hamilton Beach 31197 120 Watts Toaster...
My stove is flashinang and beeping f1....model number 790.94859301 whats it mean ...is my kitchen gonna go boom
that code says you have a problem with the clock assy. and it also has a computer board built into it,the part number is 316557511 and it's around 100 dollars.you can try unplgging the stove for 5 minutes and plug it back in,if the code comes back change out the clock assy.
May 11, 2011 | Kenmore Ovens
Drive rod will not return to top position.
Open up the owners manual, review the parts list diagram blowup. remove the four screws (allen key) and pull top head off unit. You need to get at part #116, a plastic shock absorber that breaks off and falls between the main drive piston and part #120 piston cup. its a $15 part and $10 to ship it.
Dec 18, 2010 | Porter Cable RN175 Roofing Coil Nailer
Model JVM1790SK 01 Where/how do you change the
This is a pretty bad design, sometimes you can just remove the upper grill and access the light assy. If the panel is to tight to work in to change the light,you get to take the whole micowave down and remove the outer wrapper to change the light bulb. This is also not a standard bulb (part #WB25X10019). You may be able to get one from Lowes or Home Depot actually Sears would be a better bet, otherwise you will need to order one from an appliance parts outlet. Hope this helps and sorry I didn't design the thing I just fix them.
Jan 24, 2010 | GE Advantium 120 Convection/Microwave Oven
I have locked my Kenmore self cleaning stove, now it won't open
Sorry you gave the sereial # for the oven. Need model #. Here is an manual that might work for you. cout and past in address bar.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0309524.pdf
Or you can go to this web sight and look up your oven.
http://www.managemyhome.com/mmh/answers/Answers.action#l4q106688
Good Luck
Dec 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Convergence trouble philips mod 51pp9303h/17
You can get a convergence kit with a photo instuction guide from www.TvRepairKits.com. The kit is for your exact model and includes the 6.8 ohm resistors.
Dec 07, 2008 | Philips 55PW9363 55" Rear Projection...
A Broken Stove
whats the entire model number?? and you cracked the main top glass assy??? ill look up tha part for you, not a teribly hard job, but depending on glass may be expensive
Nov 16, 2008 | Frigidaire FEF366 Electric Kitchen Range
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
88 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
