Question about Viking VGIC485-6G Gas Kitchen Range
One burner will not spark for ignition.
My 36" viking cook top does not spark on front left burner,grill and 3 other burners are fine . I replaced the spark mod. about 1 yr ago because it would not stop sparking even after the burner was lit.Do you have a suggestion? Thanks Ron.
    Novelist:
  • 101 Answers
The spark mod. needs to be replaced again. Check and make sure that the wires are connected to it good though and that they have a good connection. If all looks well though you will most likely need to replace that spark mod. again. Let me know if you have any other questions and if this was helpful. Good luck.
Posted on Jan 22, 2009
Viking range burners won't light
from I review I found it might be this...Simple replacement of Glow Bar igniter requires removal of entire front panel with many screws
so sounds like your igniter might be shot - it heats up to ignite the burners - easy fix - get a long torch lighter and just light the gas after turning it on -
Nov 05, 2017 | Viking VGIC485-6G Gas Kitchen Range
Rotisserie burner has to be lit with a match and will not stay on by itself. I have to push control knob in, even after it is hot. Also looking to replace igniter for left burner. Thanks.
From what you are describing, it sounds like your rotisserie burner may have a bad thermocouple. You can order the parts from Viking, the igniter for the left main burner will require you to remove the front panel to replace, but is fairly straight forward after that. To replace the thermocouple, you will have to fish it down from the burner and under the grill to behind the front panel, not hard, just time consuming.
Jun 19, 2011 | Viking VGBQ410-3RT Grill
I have just replaced all the ignitors and the spark control module on the cook top burners. Prior to this the back burners would cause ignition spark continually when lit. the front 2 burners could be...
first check to make sure all the burner tops are setting correctly on the burner base, if not it will make the flame uneven. the way the igniter works is once they feel the flames on them they will stop sparking. make sure the flames are not too low and they are touching the igniter. check them one at a time. if you have any questions message me back thanks
Apr 08, 2011 | Viking Kitchen Ranges
My Viking Range top has 4 burners and the automatic ignition on the left two burners do not wok. Can hear clicks and gas but no ignition. Can manually lite them. Any ideas?
Sorry to read about your problem, I hope this helps you out.
your lite tube may be clogged, or take a needle and clean the hole's next to the lite tube on the range grills..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 19, 2010 | Viking Cooktops
Viking gas stove top ignitors sparking incorrectly
all ignitors spark at the same time no matter which burner is turned on. If you are having trouble with one burner not lighting try cleaning around the ignitor with a small screw driver so the spark has a good path to ground.
Mar 19, 2010 | Viking Kitchen Ranges
Our stove is clicking when we are not trying to ignite it. The clicking comes from the starters of the front three burners. What should we do to fix it?
this cook top uses sw's n eachburner control shaft. one or more than one is bad . i would replace all . all the same . they slide on burner shages and connect to each other . some units are pre wired and you will have to pur the harness with the sitches . not a hard job . the spark moduel could be bad but i don't think so .. mm
Dec 08, 2009 | Viking Professional VGRT362-4G 36 in. Gas...
Viking Gas Burner issue?
is this a sealed burner unit? if so the burner base (the heavy brass part under the burner cap) has to be sitting just right. you will notice that it has holes around the the sides make sure that where your ignitor sparks to it that it aligns with the lowest hole on the burner base. if you have a great flame all around the burner after checking what i mentioned i would replace the spark module. if it continues to drive you crazy with the noise - just unplug it. the burners will continue working fine without power.
Dec 23, 2008 | Viking 42 in. Professional Series...
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Sep 30, 2008 | Viking 48" 6 Burner, Grill Professional...
Viking VGIC485-6G Gas Kitchen Range Logo
365 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
