Question about Citizen Eco-Drive AT1000-50E Wrist Watch
How to zero the chrono second hand( doesn't reset to zero)
Resets to the 5 seconds instead of zero
  • 2,334 Answers
Paste this link into your browser, find your movement caliber number and download instructions how to reset your Citizen watch:
http://www.citizenwatch.com/COA/English/settings.asp
Do not forget to rate, please.
Posted on Jan 22, 2009
The time is accurate, the chronograph second hand works perfectly, stop and reset to zero. The problem that I notice is that the small hands on the left and right do not reset to zero position
This drove me mad when I had a battery changed! In the manual there was a section on zeroing the Chrono hands on my Seiko. Pull the crown to the first (or may and been second) stop and press the button nearest the dial. Each push will move it one second. Stop when you get to 60 and push in the crown.
Oct 09, 2015 | Watches
How to reset the chrono function of a Tag Heuer Aquaracer Calibre S CAF7113.FT8010 after a battery change
Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works..
Jan 17, 2014 | Tag Heuer Aquaracer Calibre S...
Please clarify use of the 3 smaller dials and how the hands to each are set and reset
The small bottom dial is seconds counter and there is no option to set or reset it as it is part of the main gear train - it just counts the seconds. Top right dial is 1/10 seconds counter and runs only when the chronograph function is engaged. One full circle indicates 1 second. Top left dial is 30 minutes counter and runs only when the chronograph function is engaged. One full circle indicates 30 minutes, two circles = 1 hour. The big centre seconds hand is actually Chronograph hand and runs only when the chrono function is engaged. So, the chronograph hand and two top dials works all together when chrono function is engaged. To start chrono: push upper button once. To stop chrono: push upper button again (once). To return all hands to zero: push lower button once. There is another option: if you already stopped chrono by pushing upper button, but want to continue counting without returning hands to zero, push the upper button once more and the counting will start from the point where it stopped. You can repeat this as many as you wish - it will count on and on, till you will stop it and reset to zero. Fine tuning of chrono hands can be made by pulling the crown half way out and while leaving in this position pushing and holding one of the push buttons (which one - depends on movement caliber). Watch has an tachymeter function as well (big inner ring). Learn how to use it by browsing through my Tips and Tricks- it is explained there. Rate me, please.
Feb 28, 2011 | Calvin Klein K7547107 Celerity Watch for...
My Tag Heuer chronograph will not reset to zero.
Try the following, which I discovered by accident on my Tag Professional. Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works for you. Geoff
Feb 11, 2010 | Tag Heuer Aquagraph CN211A wristwatch
Need to reset the tachymeter on my Guess Steel watch . The dial resets it's self to the "7" location instead of "12" on my watch. Is there a way to recalibrate the watch?
This is chronometer that's need reset. Tachymeter is usually located on bezel or inclined ring and is used for speed calculations of moving object over the given period of time. Ok, back to your chrono hand resetting. Pull out crown and then push the upper button and hold it. The chrono hand should start move and you should be able to adjust it. If this doesn't work, try the same with lower button. When adjusted - push the crown back in. In fact there are very many variations how to reset chrono hand, but exact advise can be given if the movement caliber of particular watch is known.
Rate me, plz.
Jan 11, 2010 | Guess Stainless Steel Chronograph Watch...
I have a seiko chronograph sports 150 watch; had the battery changed a few day ago and just noticed that the second hand & stopwatch hands are not 'centered'. is ther a way to reset this ? cheers
As jimmyguru said.
1. Pull the crown to the second position (all the way out)
2. Push and hold the reset button and allow the chronograph hand to rotate near the 12 o'clock position.
3. Release the reset button.
4. Repeatedly push and release the reset button to find tune the hand position until it is right at 12 o'clock.
5. Push the crown back in.
Nov 05, 2009 | Seiko SNA553 Alarm Chronograph
The large second hand for use in the chrono mode rests at the 11:58 position and resets to this position instead of 12:00?
pull out the crown to either the 1st or 2nd position and use the top and bottom buttons to zero out. please rate my solution
Oct 10, 2009 | Invicta Subaqua Noma Iii S
Re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. ashfaque.r@googlemail.com
May 18, 2008 | Seiko SNA553 Alarm Chronograph
Seiko chronograph alarm
Solution #3 (Posted by Guest on 5 Mar 08) is spot on. Quick and easy method to reset the chrono hands (it was not in my Seiko manual).
Interestingly, this can also be used to set the chrono ahead (or behind--with a little math) for offset timing measurements.
Jan 13, 2008 | Seiko SNA553 Alarm Chronograph
The watch stops instead of the chrono
On this type of watch the second should not be working unless you are in the chrono mode. The lower dial should be the only indication of the seconds when not in chrono mode. You probably need to have the chrono reset and shown how the functions work. Try a Fossil location they will be able to tell you how to work this watch. It does not sound like this is a major problem.
Dec 03, 2006 | Fossil FS3105 Wrist Watch
Citizen Eco-Drive AT1000-50E Wrist Watch Logo
800 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
