Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore 795 bottom freezer - cont.
Hi! The error code is dH with no cooling in the top compartment but I still have ice cubes in the freezer. It will re-set and show temperature in the read-out but no cooling occurs. Catriver kindly described the fusable link problem this may indicate. However I did not have the correct error code at the time. Just looking for verification before I have parts all over the kitchen. Thank you so much, Spiritcat
  • 1 more comment
  • Jacquelyn Paull Jul 05, 2007
    I have opened the cover in back of the freezer but what is there does not look like the picture. There are no orange or brown wires nor a plastic packet. When I plug it in the little fan works. This is what is there: (Thank you so much for your help!)
    This is the right side
  • Anonymous Apr 17, 2009
    The code ER dH come on, but if I unplug thr ref. the temp come back to 37 & 0 for about four hours then back to ER-dH message.
    Kenmore 795
    President:
  • 878 Answers
Spiritcat, the sensor and fuse will be in a plastic packet tucked in on the right upper corner of the evaporator. You will have to remove the freezer back panel. It's easy to remove. The fuse should have a brown and red wire to the harness and the sensor will have 2 orange wires. You can ohm out the fuse when you unplug the harness. If it's bad you will not show any continuity. Check out this pic, then you will know what you are looking for. Catriver.
Posted on Jul 05, 2007
  • Ron Marek
    Ron Marek Jul 05, 2007
    Spiritcat, you are in by the compressor, you need to go from the front. The evaporator. The freezer compartment. The back panel will have to come off to expose the evaporator. If you have an ice-maker you will have to remove it. Catriver.
I have a Kenmore Elite 795 bottom refrigerator. I keep getting an error code r dh. I cycle the power & it goes away for approx. three days. looking for a proper fix
Defrost problem when the defrost process fails to reach the required temperature to properly de-ice the cooling coils.
http://www.searspartsdirect.com/refrigerator-repair/error-codes/kenmore-refrigerator-error-codes-for-795-bottom-freezer-models.html
When you cycle the power you reset the code and it takes a day or so for the unit to cycle the defrost. Suggest that you ensure that the vents are not blocked.
Hope this helps?
Nov 11, 2016 | Kenmore Refrigerators
Ice buildup Model 795-78402-802 Kenmore SN:
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 29, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker: just bought a kenmore elite model 795. I t says i...
Look for a lever to select cube size right on the icemaker.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 795-75202400 icemaker problem.
Good day,
Either the water valve opens to fill the ice maker cavity, and doesn't shut off soon enough, causing the ice maker to overflow.
Normal file time is approx. 7 seconds.
This is the most common problem.
As well, it is possible the micro switch in the ice-maker that tells the valve to open and close has malfunctioned.
This is all based on the fact that the freezer maintains a normal temperature.
To test the freezer for consistency, place a plastic glass in the freezer half full of water.
Check it in 8 hours. It should be frozen solid. Then place the glass in a plastic bowl, and lay the glass on it's side. Recheck in 24 hours. The ice should remain in the glass.
If not, there is a problem with the refrigeration system.
Nov 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Code on door says er dH on Kenmore elite refrig
This error code has something to do with a defrost sensor and happened after an extended power outage. I unplugged the refrig and it reset itself!
Jul 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Kenmore model 795 77563600 refrig side
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have error code ER dH. Unplug and then replug
Error Code - erdh
Kenmore and LG 795 Series. Model 795.77556600 but most models use the same repair. Controller Part # 6615JB2005H
To Verify correct part. Check part number for your model number at
Don't be intimidated by this repair... The 'erdh' error code indicates - error defrost heater. Replacing the controller is EASY. The difficult part is removing everything in the freezer section to access the evaporator coil but hang in there and stay with it. You will not hurt anything if you use common sense.
The new part (defrost controller) is relatively inexpensive ranging $10 - $14. Here in the SouthWest I used Appliance Parts Depot for a $10 part cost. Don't forget to have 3-4 small wire ties to secure the defrost heater, defrost sensor and wires.
It would help to write down a few notes of some of the particulars during disassembly.
I had the same ERDH error code, and my refrigerator began to warm up. I replaced the defrost thermostat assembly part # 6615JB2005H which is located inside the freezer, on the right side behind the white plastic panel.
(See Diagram Image) I accessed it by removing the freezer door, all components inside the freezer, including the slide rails / tracks mounted on the sides of the freezer. Be careful when removing the rear white panel because an evaporator fan is mounted on the back of it and plugs into the back left side of the freezer compartment. You just saved yourself about $375 or more.
Stay With It & Good Luck!
Feb 17, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Nov 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer working fine but refrigerator not cooling
Do you have the ER DH error message showing? If so, it is a failed senser, an $11.99 part that many of us are having trouble with.
May 18, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Er dh ken bot.fridge. 795.77552600
one thing to try first is make sure there is enough air flow in the freezer and that the airway between the freezer and refrigerator's is free and clear
Mar 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
471 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
