Question about Maytag Washing Machines
What size is Maytag LAT8506AAE - Maytag Washing Machines
What size is the tank on a model #M3DH30B2A
This model holds 45 pints, or 22.5 quarts.
Jul 15, 2015 | Maytag M3DH30B2A Dehumidifier
How do you select the load size on the Maytag Bravos Top load washer?
This machine is equipped with technology that allows it to sense the load size and will use the appropriate amount of water for that load. Takes the guesswork out!
Apr 21, 2010 | Maytag Bravos MTW6600T Top Load Washer
Maytag Washer lid switch
Ohm out the blue/ blk terminals on the sw (remove wire harnes first and notate wire color connection) with an ohmmeter-- Reading should be zero (closed lid position)
Then ohm the ylw and white sw terminals-- reading should be 0 as well.
If I am not mistaken this sw has a plunger that sticks out, if hte unit goes off balance this could push the plunger in. to reset- pull the plunger out
Lou
AFFORDABLE APPLIANCE REPAIR
(949) 855-0788
Jun 20, 2009 | Maytag LAT3600A Top Load Washer
Washer is "dead." Was stopped after fill up, and now no power.
Hi, I would check the lid switch first. Remove the two screws that hold the control panel to the cabinet and let it rest on the hinges. Locate the lid switch connection and either test it for continuity or use an insolates wire and jump the switch by inserting the wire into the gray and brown wires. Turn the washer on and see if it works.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
MAYTAG LAT8506AAE WASHER - TERRIBLE NOISE/VIBRATION ON SPIN
Try this for re-setting the balancing mechanism:
With the washer empty, tip tip it forward so that it is just sitting on the front feet. Hold it there for a few seconds, then gently lower the back down. (Often there is a mechanism in the back feet that automatically levels it for you--if this doesn't work, check that the back feet are not damaged.)
Mar 16, 2009 | GE WPGT9360EPL Top Load Washer
Washer not spinning enough to ring out cloths
I have the same problem with my Maytag LAT8506AAE machine. Do I need to fill up any oil after the seal replacement?
Jan 24, 2009 | Washing Machines
What is the drum capacity size on the orig maytag neptune washer?
Drum size or capacity for the Neptune Model Number MAH4000AWW is 3.4
Jan 03, 2009 | Maytag Neptune Washer
Agitates forward but not reverse.
lower gear box coupling has sheared
Jul 02, 2008 | GE WPGT9360EPL Top Load Washer
Washing Machines Logo
18 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
