Question about Senco Fastening Systems No.43OOO1N SLP20 Brad Nailer/Case
Senco SLP20 not working
We have a Senco SLP20 which is a few years old. When attempting to shoot gun, it will fire once and then air is hissing through top vent and piston has not retracted. I have taken it apart 3 times and lubed everything well to no avail. Any ideas?
Thanks,
Chris
  • chris_lewis Jan 23, 2009
    Just an update of the given information, the piston does not move freely the whole travel of the tube. It sticks about 3/4ths of the way up. I don't see any cracks or anything that would cause it to do this. I have been using wd40 and oil in my repair process, though have wiped as much of it back off as possible. I would assume that the piston should move freely up and down the full length of the tube. Should I replace the tube?
    Thanks,
    Chris
  • 2,176 Answers
I would recommend biting the bullet and putting new o rings in the tool. It sounds like one is either flattened or possibly pinched. Before going that far look at the cylinder and see if it is scored. I would go to Senco's website and look at a breakdown and that would also be a source of a parts kit. It is not that hard. Let me know if you can't find any information for this tool
Posted on Jan 22, 2009
  • David Ford
    David Ford Jan 23, 2009
    I would definetely not use WD 40 as a lubricant on the O rings, Yes the piston should move freely but with a slight resistance of the piston ring, I would still recommend putting a new o ring kit in it especially after the WD 40. Like the other comment use some silicone lube on the rings during assembly but don't pack them full.
  • James Grazzini
    James Grazzini Feb 20, 2017
    How do you remove the cylinder?
    President:
  • Senco Master
  • 1,388 Answers
Senco makes a line of nailers including the slp20 that use a firing valve (part # ba0119) that fires piston when trigger is depressed. These guns do not use oil because the oil will swell the rubber parts in the valve. When the rubber swells and tears slightly, symptoms that you describe will develop. Also remove the cylinder and look for cracks and make sure that the lower oring (LB0030) is in place and that tiny vent holes are clean. The lower oring is the checkvalve and causes the piston to retract. Use only the slightest bit of silicone lube on orings. Parts are available at www.toolpartsdirect.com. Good Luck
  • John Trevino Jan 23, 2009
    The slp20 uses a fiber/plastic ring on the piston with a rubber oring under. This plastic ring does not need oil. Wd40 causes orings to swell. Could be that the oring under the plastic ring is causing problem. Test would be to remove the oring from under plastic ring and try piston in cylinder again. You should be able to use the gun without the oring under plastic ring unless the piston is then too loose in cylinder. I have seen many of these guns with rubber oring instead of plastic. This does not work as well and will jamb the piston in cylinder. Good Luck
Paslode framing nailer: compressor powered, hisses but will not shoot nails, appears to be in the sliding mechanizism that touches the wood first before it will shoot, help
I've used paslode for years and whenever there was a "hiss" of air and no fire- it was o-rings- When were the o-rings changed last? And how do you know they are in 'good shape'? You can't tell by just looking at them. If that isn't the problem then I can't help. Just as an aside- do you oil the gun (down the air intake nipple) every time you use it? Lack of oil will wear out o-rings fast. Sorry if this isn't overly helpfull but most gun problems are o-ring or seal related unless you've worn out or damaged a mechanical part.
Feb 10, 2013 | Air Tools & Compressors
Senco a200bn not working
Senco sold the A200BN under the Accuset line around 1999. They were not on the market for long because it was not a reliable tool and now parts are extremely hard to find. If you go to www.toolpartsdirect.com and search by model number they have a good breakdown of the tool and a few parts available. If you're having feeding problems I'd look at the rail, feeder shoe and feeder springs for bends, breaks or blockages.
Apr 15, 2012 | Senco Fastening Systems No.43OOO1N SLP20...
SLP 20 Leaks air from top and I Just replaced the chamber and o Rings.
The slp20 uses a firing valve part # ba0119 black plastic w/rubber boots. This valve is what prevents air from leaking thru top of gun. If pin hole has developed, or oring # lb0012 is not in place under the firing valve or if the retainer # bf0149 does not fit snugly on cylinder or has cracks, the gun will leak. Assuming oring is in place and retainer is good, suspect firing valve. Good luck
Mar 26, 2011 | Senco Fastening Systems No.43OOO1N SLP20...
My Senco SFN1 finish nailer will not shoot a nail. When the trigger is pulled air comes out but no nail is shot. Thanks,Steve L
Not sure about Senco but most have latch you can open to expose firing mechanism. Nail sometimes gets jammed and will not allow driver to fire or if not nail push driver ****** all the way back into gun then see if gun will fire.
Oct 25, 2010 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
Framepro 602 only shoots air out a hole in the top when the trigger is pulled, occasionally shoots a nail but more often just shoots air
You have some worn out o-rings in your gun. Get a Senco repair kit #YK0360, use everything in the kit and your gun will be as good as new. Type "senco yk0360" in your search engine and shop around, the kit should be around $45 - $50.
Oct 11, 2010 | Senco Air Tools & Compressors
Gun is only a few yrs old and has had moderate use. Problem is that when depressing the nose piece I get a hissing of air and it will not fire. It will sometimes fire but after a few nails it just hisses...
Your o-rings are wore out. Paslode makes(made) a Tool Repair Kit, PN219235 and Trigger Valve Kit, PN219224 for your gun. Always use all of the o-rings in the kit and liberally lubricate them before installing them using grease in the kit or nail gun oil. If the kits are no longer available you'll have to get a breakdown of the gun, (www.paslode.com/uploadedFiles/PowerMaster_Plus_Parts_Diagram_Schematics.pdf) and order all of the o-rings. Be very carefull to put everythng back together properly, you are working with a gun.
Aug 31, 2010 | NRS Paslode 501000 Powermaster Plus...
Shooting two nails instead of one
i would double check the plunger to make sure its resetting after each fire.
Oct 30, 2009 | Senco FP18 FinishPro 18 - Gauge Brad...
Senco 701xp, I press to nail and get a air hiss as low nails
the problem is in the safey area of the gun, it could be the safety is only partially pushing in (what is sounds like) also, the track may be dirty and need lubed. Spray WD40 on the track and up the nose.
Also, check the thumbscrew on the back of the track by the handle and make sure the track is pushed all the way forward and tightened up
Jul 11, 2009 | Senco & Frame Pro 702xp Framing Nailer
Slp20
By replace I take you mean o rings? If so I would look to see if one got pinched upon reassenbly. If not let me know exactly what you replaced and I will look at a breakdown and see if I can help.
Jan 25, 2009 | Senco Fastening Systems No.43OOO1N SLP20...
Senco Fastening Systems No.43OOO1N SLP20 Brad Nailer/Case Logo
2,007 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
