Question about Sewing Machines
Singer Sewing Machine
I have a problem with the needle going down, hitting metal and when looking at the bobbin area the mechanism does not move. Is this a major repair issue?
I have a problem with the needle going down, hitting metal at the bobbin area. I replaced the long gear and lower. Also gear gear under bobbin
Posted on Jan 22, 2010
    Scholar:
  • 65 Answers
A bent needle will hit the metal. If it continues you will need to adjust the needle carrier. hopefully that isn't bent, but if so I don't believe that the replacement of it will be too costly.
Posted on Jan 24, 2009
2 Suggested Answers
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
Simplicity sewing machine SL 9240 was giving to me and when I try to sew the needle keeping hitting the bobbin holderr.
On the right side you have two knobs to make adjustments. The lower knob will move the needle left or right so it won't hit the bobbin holder.
May 31, 2014 | Singer 7442 Mechanical Sewing Machine
Singer 2263 needle hitting something in bobbin area (loud thunk) and needle moves
try taking the bobbin out and putting it back in the bobbin
case if it's a top loading bobbin
if it's a side or front loading bobbin make sure the bobbin case is
inserted correctly
if the bobbin and bobbin case are inserted correctly then
it sounds like the sewing machine could have a timing
problem and needs to be checked at a sewing machine shop
Nov 12, 2012 | Singer 2263 Mechanical Sewing Machine
How do i adjust bobbin tension on singer 4210
Open bobbin area and look at your bobbin carrier for a tiny metal screw that holds down a metal piece to the plastic carrier. Tighten the screw. Be careful though...the plastic can strip.
Sep 16, 2012 | Singer Inspiration 4210 Mechanical Sewing...
My old Singer sewing machine won't pick up the bobbin thread. It is threaded properly and goes down to pick up the bobbin thread, but comes up with no bobbin thread. What to do please?
Hi, try re-timing the machine. Select "straight stitch," then take the bottom off the machine to see underneath the bobbin case area. Open the faceplate and look for two marks on the needle bar around where it enters the machine. Take out the bobbin case to see the hook. Turn the balance wheel toward you so the needle is going down. Stop turning when the needle is just about to start on its way up. The bottom mark on the needle bar should be just about to enter the machine, and the point of the hook should be just above the eye of the needle. If it isn't, tilt the machine backward and loosen the two screws on the vertical gear so you can move the hook to where it should be. Tighten the screws and put everything back so you can test your setup. If it sews a straight stitch correctly, try it on zigzag wide stitch. If it misses one side, repeat the timing process.
Jan 22, 2011 | Singer 7462 Mechanical Sewing Machine
WHEN TRYING TO PICK UP THE LOWER BOBBIN THREAD - HAVE NOW BROKEN TWO NEEDLES. THEY BEND AND SNAP AS IF THE MACHINE IS OUT OF SINK WITH ITSELF.MY MACHINE IS A SINGER INSPIRATION 4220 . (I DONT REALLY KNOW...
Make sure the needles are installed with the flat side facing the back of the machine.
Open the bobbin area and hand walk the needle down to see what it is hitting.
Check the bobbin case and shuttle to be sure they are in place.
Needles can also bend and break if they are too small for the thickness of the fabric.
Feb 28, 2010 | Singer Inspiration 4210 Mechanical Sewing...
Bobbin not turning, possible motor/gear issue?
You have a broken vertical shaft gear. It's very easy to replace if you are mechanically inclined. The gear can be purchased for between $8-14 from a sewing repair store and I can walk you through the process.
Jul 19, 2009 | Sewing Machines
Breaks needle
Yes they can indeed go out of time and breaking needles is the most likely cause. To solve timing problems you will need a sewing machine engineer though. The part which needs adjusting would be the area above the needle-the needlebar but it is a fiddly affair only to be attembed by someone who can repair sewing machines. It is also a fairly expensive repair as it is very time consuming. However-don't assume it is that. Firstly make sure the new needle is in correctly-the most common cause of problems is needles in wrong direction! If bobbin opens at front then the flat part of the needle faces the back. If bobbin area opens at side then the flat side of needle faces the body of the machine to the right. Check needleplate for damage so that new needle does not catch. File it smooth if you need to! Check you are using a good quality thread as cheap thread causes no end of problems. Guuterman is the best I found.
Feb 14, 2009 | Singer 8280 Mechanical Sewing Machine
Singer Touch & Sew 7462 - Needle hits bottom of bobbin case
With the needle hitting the bobbin case , it sounds like it might be out of time. Which I am sorry to say is not an easy at-home fix.
Jan 17, 2009 | Singer 7462 Mechanical Sewing Machine
Needle Hitting Solid Metal
On my machine, that usually happens when the needle gets bent. Try replacing the needle.
Nov 08, 2008 | Euro-Pro 9120 Computerized Sewing Machine
Sewing Machines Logo
268 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
