Question about Panasonic NV-HS1000 S-VHS VCR
No more image (only snow) the audio is ok.
Like if the video head didn't read anymore, I disconnect the drum, and I get exactly the same, for the REC it is the same.
The audio is good.
  • sparoz Jan 22, 2009
    I already clened the video head !
    Problem Solver:
Do you get black topedoes on the screen if you do this a sign of a faulty head and will need replacement. disconecting the drum will be of no avail as it cannot pick up the video signals. you may well be in the need for a head clean and an audio head clean, including the tape guides and rollers. you can purchase a head cleaning tape, get the wet type, unless you are expeirenced it is best not to d.i.y clean use the cleaning tape only or you could well damage the pick up heads, if that doesnt work get a pro to look at it ,anyway head cleaning would be my first port of call.....David Delaine
Posted on Jan 22, 2009
Only the audio is recording, NO VIDEO, onto the hard drive. The JVC reads, "Lens Cap" even when the lens cap has been removed. Flip out screen is black. Only shows record settings; Battery life,...
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jul 22, 2011 | JVC Everio GZ-MG21 Camcorder
I have a cannon 6030 copier in my office that is not serviced anymore. I recently changed the toner, following all the directions from the manual. Now It only copies blank pages. It has no other error...
manually jam the paper & see if there is any images on your drum. if no image is there, problem will be in your primary charging. Corona wire may be broken repair it.
if there is image on your drum check if your transfer is ok. replace your transfer corona wire
Apr 14, 2011 | Canon NP 6035 Copier
I received a JVC DR-MV80B DVD/VCR combo and the DVD's play fine, but on the VCR side, the video doesn't play - only hear audio. Is this a product issue, or something that can be repaired without costing...
Try cleaning the video heads - assuming you got a 'snow' image with audio, see if it helps. Otherwise the VCR might require a head replacement/mechanical realignment, which could be expensive/uneconomical.
Mar 19, 2011 | JVC DR-MV80B DVD Recorder / VCR Combo
Go video VR4940 VCR video recording has sound but no picture
You can try cleaning the video tape heads. The vcr has 2 different heads. One for audio which is fixed and a drum head for video with 2 heads on it that rotate. The best way to clean them is to take a lint free cloth ad wrap it tightly around your finger. Put some alcohol on the cloth and place it on the drum. Then rotate the drum as you hold your finger against the drum. DO NOT move your finger up and down as you can brake the head off. The other option is to go buy a head cleaning stick. It's a piece of chamie on a plastic tongue depressor. I've cleaned hundreds of them with my finger though. You can clean the whole tape path with the rag. Good Luck.
Nov 30, 2008 | GoVideo VR4940 DVD Player/VCR
NEC VH-605 VCR - Very Snowy Picture
Video head needs thorough cleaning. If no head cleaner, then run a few long tapes through it in the fast scan mode since the tape itself is abrasive and will over time remove debris from the heads. If that does not do it, try a chemical cleaner to dissolve the material.
Sep 01, 2017 | NEC Audio Players & Recorders
Sony VCR plays/recordes in EP mode but not in SP mode - need schematic
sounds like it needs a good cleaning, you will notice this problem in sp first when needs cleaned. however if you had done this I would go over it again and if not then change the video head
Nov 19, 2007 | Televison & Video
VCR Play Back is OK, but Recording produces Blue Screen on playback
If the heads are TOO dirty, a head cleaner will not help. If you are cinfident enough to open up the recorder, then they can be cleaned manually.
Disconnect the VCR from the mains.
Remove the screews from the side and back (if applicable) of the lid.
Remove the lid.
Look at the large drum (set at a slight angle) If you gently rotate the drum you will see 2 or 4 small sensors set into the drum.
Tear of a clean piece of A4 paper about 1inch square.
Hold between thumb and first finger and rub the centre of the paper against each sensor in turn. Make sure the edge of the paper does not catch the sensor.
After each sensor check the paper for dirt (black marks) and change paper if need be.
Try a recording / playback.
Repeat if necessary.
Nov 08, 2007 | Philips VR330 VHS VCR
Plez help
Never store your tapes or camcorder near anything magnetic. Sounds like it could be a dirty tape head (the one that reads the tape) or a loose connection with the wires. Try a different cable first if you can, then go on to cleaning the tape head with a Q-tip and 99% alcohol. The tape head is located on the shiny round metal thing that the tape runs on. Questions? Don't hesitate to ask. Your tape should be fine as long as it wasn't near a magnet.
Oct 28, 2007 | Video Cameras
No image displayed
DEar sir, the small wireles camera has power output of 640 milliwatt & is so less for digital cards & DVR .. digital input can accept either 0 or 1 , & these wireless cameras are not having stable video , unless u use a strong trsnmitter , try the proces using a corded camera ..u will not see any snow effect . Out put direct to TV will be Ok for these wireless cams .
Aug 20, 2007 | Sabrent Sbt-Scnv / Color / Mini Wireless...
Panasonic NV-HS1000 S-VHS VCR Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
