Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Need to Fax from my Computer using an Epson Workforce 600
I just purchased an Epson Workforce 600. With my previous All-In-One printer (HP Officejet 7310) I could fax a file directly from my computer; specifically, pdf files from Adobe Acrobat by "printing" the file to the "fax machine". I can not figure out how to fax from my computer with this new Epson Workforce 600. Calling Epson was no help.
  • 1 more comment
  • ndryan55 Feb 09, 2009
    Need to fax electronic files on my desltop. Usued to "print to fax" How on epson?
  • Anonymous Mar 11, 2009
    same
  • dalegaspi Mar 21, 2009
    I have the exact same dilemma. I am trying to send a fax from file...in the "print" option there is no option to send to fax..adding a fax machine from the system settings doesn't find the printer...i looked all over the web for answers and read through the manuals...it seems that it does not have this capability to fax from file...which is a HUGE OVERSIGHT...
    Sergeant:
    Champion:
  • 357 Answers
Check your software fax settings.
Good Luck.
Posted on Feb 16, 2009
  • John Sparozich Feb 26, 2009
    I tried to help, so what is INAPPROPRIATE about that?
  • 31 Answers
GET YOUR SOLUTION FROM EPSON
HERE IS YOUR SOLUTION
http://www.epson.com/printer/prob676ijt65/solution
a17
Posted on May 22, 2009
Epson 630 workforce won't fax to some numbers.
followed edger allans remedy and now faxes that where not answering before now are. i think mostly because i had it set to, 1 ring to answer and i changed to 6. thanks.
Feb 07, 2012 | Epson WorkForce 600 All-In-One InkJet...
My epson workforce 600 will not print in black. Ive did the head cleaning many times. Ive bought the cleaning solution used that per directions and then again cleaned the head many times. Still it will...
Hello, Rvarnett -
I see someone posted a similar question about the Epson Workforce 600 on a different repair help website in 2012. Read the solutions provided there:
https://www.fixyourownprinter.com/posts/73053
Do you know how old the printer is - how long you have owned and used it?
It MAY just be time to purchase a replacement printer and send the Epson Workforce 600 to electronics recycling. My personal experience with Epson printers, and I have owned more than one, is that they do not seem to last much past 6 years before they do not work properly.
Jan 12, 2018 | Epson WorkForce 600 All-In-One InkJet...
I have an Epson Workforce 610. It used to send faxes just fine with only minimal errors. Now, I only get error 5303 for the last two months. I am using it wirelessly from my computer, and it prints...
Try this : Look for Setup on your printer and press OK button. Go to Fax Settings, press OK, then go to Communication and press OK. Turn off ECM and V.34. Try re-sending your faxes.
Dec 10, 2010 | Epson WorkForce 600 All-In-One InkJet...
Have an epson workforce 610 series.... the machine will not turn off using the power button.. weird.. how do you get the thing to turn off w/o unplugging it... tnx.. cecile
When you push the power button does a warning show on the printer's screen about "Saved fax data/ received will be deleted?" If it does, select the YES option and the OK button.
Hope this is your solution
Aug 21, 2010 | Epson WorkForce 600 All-In-One InkJet...
Epson fax hooked to magic jack communication error
I had same problem when I used the dual jack. I had to change it. I had the dual jack which would make it easier to use when I was going to send a fax.
Good Luck
Feb 09, 2010 | Epson WorkForce 600 All-In-One InkJet...
Epson workforce 600 continue to get paper jam error and there is no paper jam..
If this message appears when you turn the printer on it will need a repair, this will be down to a sensor fault.
If this message appears when you try to print Check you are using the correct paper type and size settings, on the printer if being used standalone or via the printer driver if using via a computer.
Also try using a different paper type and brand ideally Epson paper as it is an Epson printer. If the fault continues the printer will need a service.
As this printer was released this year you should be covered by some form of warranty, contact Epson for a service.
Dec 13, 2009 | Epson WorkForce 600 All-In-One InkJet...
I get error 0408 when i try to fax. Using epson
Communication error,try defaulting the machine ,check the line with a good telephone make sure you have dial tone.
Good luck
Sep 21, 2009 | Epson WorkForce 600 All-In-One InkJet...
I lost my install cd for my Epson Workforce 600
all drivers and software for Epson printers are available on the Epson Support site just type in the web address with a .com and seek support button and search.
Cheers
[please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 15, 2009 | Epson Stylus C46 InkJet Printer
Trying to connect new laptop wirelessly to Epson Workforce 600
You need a wireless router and then follow the directions that came with the printer.
Jul 13, 2009 | Epson WorkForce 600 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
1,825 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
