Question about FIC Ice Cube (ic-hu61) Barebone
Need update to bios ice-cube ic-hu61 - FIC Ice Cube (ic-hu61) Barebone
My beko American fridge will not give ice cubes just crushed ice
You might need a new Control panel for your Ice dispenser.
Sep 20, 2014 | Refrigerators
My ice maker makes ice but melts fast
All ice is the same...at or below 32FH is ice, above 32FH it's water
Perhaps your ice maker is making very small ice cubes that melt faster then bigger ice cubes, if so the your ice maker needs to be adjusted too make bigger ice cubes.
Aug 10, 2014 | Scotsman DCE33PA1BC 15in Built-in...
Update phoenix bios
1 download bios file
2 remove bios ic
3 inserting bios copier to bios
4 coppy bios file and paste to bios ic
Aug 30, 2013 | Acer Computers & Internet
Replacing power supply
Good for you. Let us know when it is done. If you want to know how to do it, Just ask.
Nov 22, 2012 | FIC Ice Cube (ic-hu61) Barebone
Ice maker does not reject ice cubes. I can see ice cubes in the ic maker bur they do not rotate out to the tray.
The timer is either hung up, or bad. take the cover off the timer front and watch it cycle through. you can make it hurry up if you know where to put the jumper wire. You can probably get a new plug and play ice maker for around 60 bucks. My experience has been if it hung up once, it'll do it again.
Sep 23, 2010 | Maytag Refrigerators
Blue Ice cube maker only make 4 instead of 12 cubes ?
It may just need a cleaning. Use approved cleaner for this modle and sanitize the bin after the cleaning. If it is making some ice, most likely there is not an issue with the charge.
Jan 22, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Will the motherboard support both ATA100 and ATA133 IDE hard drives?
depends on the motherboard and power supply but i would say yes because theres very little power requirement difference between them
Nov 20, 2009 | FIC IC-VG61 (IC-VG61 (ICE-CUBE)) PC...
Can not get the thing to see past 256 mb i have installed 512mb, 1Gb, & 2GB and all it can see is 256
Some system bios have a setting install mode which will keep the memory at that level and im pretty sure even if you just set defaults it stays unchanged on some. You have to find it manually and you'll be up and running. Cheers from Scott
Nov 09, 2009 | AMD FIC Ice Cube HU61 Athlon 64 Small Form...
Can I buy just a motherboard for an hu 61
you can buy replacement motherboards for you HU61 you have to look for a mini itx board. you can check on the net for mini itx boards.
Aug 06, 2009 | AMD FIC Ice Cube HU61 Athlon 64 Small Form...
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
FIC Ice Cube (ic-hu61) Barebone Logo
29 people viewed this question
Top FIC Computers & Internet Experts
David
David
John Anderson
John Anderson
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
