Question about Kenmore 23822 Top Load Washer
Washer shuts off and I have a burning smell
I did a load of laundry the washer shut off, it still had water in it. about an hour later i tried and it stared up and spun the laundry. It smelled like something was burning.
    Novelist:
  • 101 Answers
You might be starting to have a problem with your motor coupling. It sounds like an expensive part but it really isn't, it costs around 10 dollars. The motor coupling sits in between the motor and the transmission, it basically connects the two. When the washer goes into it's spin cycle is starts to spin the motor arm where the motor coupling connects to the transmission making the washer spin. If you smell a burning smell it may be the gasket around the motor coupling. It's a simple and cheap fix. When you tip the machine back your can put your hand between the motor and the transmission and you can feel the gasket around the motor coupling. It's about the size of a silver dollar. If it feels thin at all and you can feel dents in it or any spots that feel torn then replace it. Just remove the few screws holding the motor up and remove the black clamps and it will fall. The motor coupling will come right off with it. Make sure you unplug the washer first though. Let me know if you have any other questions and let me know if this was helpful to you. Good luck.
Posted on Jan 22, 2009
My wife put a load in last night and a couple of hours later the laundry room smelled like something was hot and the washer had stopped on the spin cylce. The control panel didn't feel hot but I unplugged...
Something caught in pump & belt burning. Motor start capacitor (If fitted) is US & needs replacing. Timer faulty, motor has burning smell, replace timer & or motor. Motor switchgear failed motor sitting there & humming, adjust switchgear or replace motor.
Dec 19, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Frigidaire front load washer SMELLS!!!!
your inner tub needs to be removed and the outer tub including the outside of the inner tub needs to be cleaned of all the sludgy soap, fabric softener,etc. that has built up in between the tubs,along with the drain tube at the bottom,you might try bleach as a stop gap,but sooner or later you are going to have to clean this out the hard way,its not fun
Mar 09, 2010 | Washing Machines
What is the issue with mildew and how do I address it? My laundry never smells clean
Any washing machine will grow mold & mildew when there is moisture in it and the door is shut. When you do a load of wash, the smell transfers to the clothing. To eliminate it, run a load just water & chloring bleach. This will kill the spores. Adding a little color safe bleach to each load or leave the door open when not using the washer will keep the problem from coming back.
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washer sounds like a jackhammer when rinsing - this is a new thing with all loads. Yesterday it shut down mid cycle while still full of water and we smelled a burning rubber smell. Any ideas?
There is only one belt on the machine (the burning rubber smell, probably). Sounds like something is wrong with the clutch /drive mechanism. Unless your an accomplished DIY'er, it sounds like a job for the Maytag Man.
Sorry.........................
Sep 15, 2009 | Maytag PAV2300 Top Load Washer
Kenmore Washer 70 Series - sheets stuck around agitator
The transmission probably stripped the worm gear that drives the drum - you would have to crack it open and take a peek.
Nov 24, 2008 | Kenmore 15864/15862 Top Load Washer
Started a new load of wash and water never shut off flooding room
you can check for a broken/cracked/ dettached plastic hose leading from the back left side of tub to the pressure switch under the main console. usuall problem is it dry rots and cracks, or comes loose after shaking/vibrating,
Nov 15, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer overheats and shuts off
It sounds like you have a bad timer. Your timer is basically a wheel that turn and opens and closes sets of contacts. Once these contacts go bad, they stick together. Your machine will basicall try to do a few things at once and over heat (hence the reason it works after it cools back down). A replacement timer should be availible from both your local appliance parts supplier and from the manufactures web site.
May 29, 2008 | Kenmore 23822 Top Load Washer
My maytag washer has a burning smell.
What model do you have.?It doesn't sound like it was spinning.A frozen pump would make the belt burn and it would leave some water in the tub .
Oct 18, 2007 | Fisher and Paykel GWL11 Top Load Washer
Kenmore 23822 Top Load Washer Logo
105 people viewed this question
Sal De
fordexpert
Robert Rankin
