Question about Tornado Tools 21.6V Cordless Drill Kit
Would like to find a 21.6 battery charger for torenado
I have a toronado 21.6 cordless dril and would like to find a charger
New battery needed for 18V cordless hammer Dril D6991
Go to home depot and see if the Ryobi, DeWalt Black and Decker or or other company batteries fit,. Otherwise I think that is a Chinese tool sold mostly in Europe or by mail order.
May 30, 2017 | Hammer Drills
How to tell iff batteries are uselss or need replacing or charger or drill itself
The first thing to do is get your volt meter and check if there is any voltage coming from the battery and compare that to what it is stopped to be. If the voltage is ok, install the battery in the drill and try to run it. If it won't run, you've got a bad drill. Next install the battery in the charger and plug the charger into your wall outlet. There should be an LED which flashes to indicate that it is charging. If you can get a full charge on the battery (verify this with your volt meter), try it in the dill again. If the drill will not rotate, there is definitely a problem with the drill.
Oct 05, 2015 | Drills
Batteries for Rockworth cordless dril
you can go to www.batteryshops.co.uk for a further check
Sep 24, 2014 | Drills
18volt cordless drill battery charger will not charge batteries
Fist you should check that if there is problem with your battery or charger. Do you store your batteries in right way when you don't use them?
You can come here (Power Tool Batteries Drill Batteries Replacement) and find if there is batteries or chargers for you.
Mar 26, 2014 | Drills
I need a battery for a metabo sb impuls hammer dril and charger drill perfect working order battery and charger lost in mooving house. has on bottom of drill were battery conects pa6-gf30 can you still get...
I saw them in the latest Metabo leaflet. They are serious producer and they shoudl keep spare parts for few years after they discontinue some product. Try to call to Metabo in your country. Juraj
Jun 03, 2010 | Metabo Drills
I have a B&D pivot plus dril-drive. How do I open it to get the batteries out to recharge them?
you don't, you plug the charger into the drill!
Plug the output cord of the charger into the socket in the bottom half of the screwdriver handle.
Jan 11, 2010 | Black & Decker Drills
What is the output of the charger for the B&D cordless drill 9049a?
The output power will be higher the the battery itself, a 14.4V will be up around 16-18 Vdc. an 18 V will be 20-21 Vdc. Now this is if your testing it with a multi meter and it is not under a load.
Dec 14, 2009 | Black & Decker Drills
Skil cordless drill model 2362 - won't charge
I have the same problem. The guys at Batterries Plus told me that 7.2 volt battereis are not easily replaced and definately not through them. If you left it charging for to long (ie over a week when you were gone like me) then the battery is never gonna charge again. You might as well find the same model of dril at skil's reconditioned site for around $40 or buy a brand new one for $60 or $70
Mar 30, 2009 | Skil 2362-01 Factory-Reconditioned 7.2V...
Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Sep 29, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Makita cordless dril Model # 6213D 12volt.
I used to pull these drills to bits for a living and all i can say is that if the brushes are intact and not too worn then it should run fine without cleaning the brushes. chances are that the motor has worn out.
Sep 13, 2008 | Makita 3/8" Dr. 14.4V Cordless Drill Kit
Tornado Tools 21.6V Cordless Drill Kit Logo
49 people viewed this question
Top Tornado Drills Experts
Tom Chichester
Are you a Tornado Drill Expert? Answer questions, earn points and help others
