I want to conect my gigastone smartbox - Computers & Internet
When turning on my technika it has a red flashing light but nothing else happens when I press the remote that came with it.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Mar 01, 2015 | Televison & Video
How do I config my smartbox Gigaset 604 IL to operate as an Access Point.
Can your wireless device connect to that SSID, using that WPA (Wireless Protected Access) key?
Sep 01, 2014 | Computers & Internet
Hello,, Am still dying with this issue in my car,, When I engage D on my 1999 Jeep Grand Cherokee V8, 4.7L or R am getting a kick sound, same as when I drive and shift from 1 to Gear number 2 am...
Thanks for using FixYa.
Check the U-joints in the drive lines. They are probably worn out thus making those kick sounds. I also suggest that you bring your car to a local shop and have it diagnosed. I will be really hard to diagnose a car problem if we here at FixYa can't even test drive the car. But I honestly think that its just the U-joint.
I hope this helps. Have a nice day.
- HotRatchet
Jan 11, 2010 | Jeep Grand Cherokee Cars & Trucks
Cable company installed wireless router for internet into smartbox, but did not wire into leviton system itself. trying to connect to internet, only wireless works. which cat5 jack do you plug into, and do...
Make sure you can go online directly to the modem. If that is confirmed, you can connect the router directly to the modem and install it using the setup CD that came with it.
Oct 23, 2009 | Leviton (102-5G108-RW5)
My box in my car for payments went crazy
it is illegal for you to touch the unit and it could void your deal and they can repo your for it. so i ould wait till tomorrow
Oct 04, 2009 | 2004 Honda Accord
Error code erased whith a smartbox
it could just be a slack cable that needs sorting, or maybe you have struck it lucky and its just warning you to stress you out sometimes the way a woman dose, weithout seeing the error for my own eyes its difficult you may just be fine
Jun 05, 2009 | 2004 Honda Accord
Error code E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Jun 01, 2009 | Canon iR 1600 Laser Photo Printer
Wireless internet not working contacted perlico and they said that lan port was not open
try pressing start, control panel, network and internet conections, network conections this should show your lan page then press on the lan you need to conect then it should be conect or bridge conections
Nov 04, 2008 | Siemens Computers & Internet
Network
hii you conect net server pc . all pc conect in switch ..then your name all pc diffence .. and net conect server pc then go net conection dailbox properties ..networking ....enabil network conection then so server pc auto ip address....apply ok  done
Jan 08, 2008 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
