Question about Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C)
My Linksys Wireless-G Notebook Adapter V2.0 is no longer working
Initially my computer said it had low virtual memory, so I took out the wireless card (which helped me fix the memory prblm, but now when I put the card back in, the internet does not work). Please help! Thanks
    Genius:
  • 1,689 Answers
Try un-installing the wireless adapter, and then reinstall it back. If this does not work, check out the configuration in both the router and in the computer. You will have to connect the computer directly to the router to check out the router's configuration.
It is also possible that the wireless adapter has failed. The only way to verify that is to try another one.
Jerry G.
Posted on Jan 31, 2009
Wireless g notebook adapter
Hi sfconagelo,
Which card; wired or wireless card? Check to make sure that the card is properly installed in your computer in device manager. If properly installed then you should be able to connect but not if your Linksys router has wireless encryption (for wireless card).
Regards,
Angel
Jul 08, 2010 | Linksys Wireless-G WRT54G Router
My Linksys Wireless G adarter card freezes my computer
Hello
If your wirless adapter freezes your system it is definitely a driver incompatibillity, thus download the latest version of the driver for your spesific os and it should work properly.
Please rate this.
Best regards
Sep 25, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
I have a wireless notebook adapter for my dell lattitude c400
Make sure that you insert the card in before booting up the computer. When Windows 2000 was created PCMCIA cards weren't hot swappable. If that doesn't do the trick, check linksys.com for updated Windows 2000 dirvers.
You can still update to Windows XP as well. Some computer stores still carry it. Wireless networking is managed much better under that operating system.
Jan 04, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
HELP with Wireless card
check the distance of your computer and router.
check the ssid and security of your wireless router. make sure to enter it in your pc with wireless card.
Oct 22, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Trouble installing wireless card
If you're having installing the wireless card, try first to run the setup CD and follow the wizard in installing the wireless card and if it didn;t finish the installation , restart the computer and make sure the wireless card is connected to the computer and let the computer detect it and then a Found new Hardware wizard will come up just follow it , but if still fail better call Linksys tech support and let one of their tech walk you through with the process also to check if the wireless adapter is bad, they are open 24/7 this is the number 800-3267114....
Hope that helps..........
Sep 26, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Dell latitude problem
Unplug card, reinstall drivers and put back card.
If system is still freezing the card may be defective.
Sep 07, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Linksys WPC54GS wireless adapter installation issue
There's a possibility that the adapter is defective. However, you may still try the following:
1. Make sure to uninstall the software if you still have it installed. Remove it from the Programs list or under Add/Remove Programs.
2. Check Device Manager and make sure adapter is not under Network Adapters nor Other Devices. It might be called Network Controller if driver is not installed correctly.
3. Unplug card, shutdown computer and when PC is powered off, plug card back and restart computer.You may insert the CD on this process, but do not run/continue the CD setup wizard.
4. When computer is back on, you should get a Found New Hardware bubble message or wizard.
Just finish the wizard and tell me how it went. Goodluck!
Jul 08, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
HP dv1000 laptop and internal wireless modem
Although you have internal wireless, you are capable of attaching an external wireless device. For example, you could attached a D-Link WUA-1340 USB Wireless G adapter (http://www.dlink.com/products/?sec=0&pid=477), or, if you have a PCI port, you can use a Linksys WPC300N Wireless-N Notebook adapter (http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1144763513196&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=1319686869B07). Either device with any brand will work just like your internal wireless. In fact, because you chose to use an external device, you may get a better wireless signal. Because internal wireless devices are inside the computer, it is more difficult to received a signal than with an external device.
Apr 20, 2008 | HP Pavilion dv1000 Notebook
WPC54G Linksys Wireless-G Notebook Adapter
Go to device manager. Double click network adapters. The linksys wireless notebook adapter should appear under NETWORK ADAPTERS. If it is there, right click the Linksys Wireless Notebook adapter then click properties, it should show THE DEVICE IS WORKING PROPERLY. If not you need to uninstall and reinstall the device.
Mar 05, 2008 | Computers & Internet
Wireless notebook adapter problems
hello!
-- try to install the adapter to a different computer to further isolate the problem.
-- if possible download and use the latest driver for your wireless adapter
Jan 19, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Open Questions:
Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C) Logo
91 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
