Question about GE 1101P DVD Player
Dvd player ge1101p. need code for using comcast remote.
I need the code to program this dvd player GE model ge1101p to be able to use my comcast remote control.
trintek
  • 111 Answers
SOURCE: Need a code for APex AD1115 DVD Player
if this remote uses 3 digit codes, try the following: 214, 215, 216, 401
if it is 4 digit, try these: 0386 0390 0391 0392 0424 0430 0436 0439 0445 0457 0459 0938 0913 0401 0949
Posted on Nov 16, 2007
  • 3 Answers
SOURCE: DVD player remote is dead
It's quite possible that something got spilled into the remote. I've had this happen a bunch of times, & the remote goes dead! What I did was to take the remote apart by first separating the two halves with a knife & a lot of patience. The two halves are connected together by little clips of plastic all around the perimeter of the remote. Once you start to pry at it, you'll see little indentations ~1/8" - 1/4" wide, every here & there...these are the clip locations. Try to separate them without breaking them. Once you have the remote apart, there's four parts to it; the two halves that you just fought with, the circuit board, (PCB), & the rubber matt that contains the buttons. What you'll need to do is to clean the PCB thuroughly with rubbing alchohol, making sure to dry it completely. Do the same to the other parts, being carfull not to break anything but at the same time being sure to get them clean! Check that there aren't any broken wires or components, resolder anything that may need it. Once you're sure that everything is connected, clean & dry, reassemble the unit by first placing the rubber matt over the PCB, (line up the buttons & make sure it's in the right orientation. Then press the front cover onto the PCB/matt while holding the whole thing aligned, then put on the back cover & click it all together with the little clips. Be extra carefull that the battery connectors go into their proper slots. You may also want to bend the battery connectors alittle bit, in such a way as to make sure that the battery makes a good contact, don't go crazy, you don't want to break them! Once you have it all back together, put in some fresh batteries & try it out! If it still doesn't work....go buy a universal remote!!! Don't worry....be happy!! Good luck!!!
Don
Posted on Feb 14, 2008
IrishDruid
  • 2712 Answers
SOURCE: Ge remote control #24921
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
SOURCE: Product code for GE DVD Player
Stopped looking in the RCA website and did a google search for GE universal remote control codes. I found it there.
Posted on May 09, 2008
  • 78 Answers
SOURCE: GE Universal Remote Code for my Insignia DVD Player NS-DVD1
if you have already tried "code search" then you may have to return that remote and get a different name brand of universal remote.
Posted on May 30, 2008
How do I program a dvd player with the new xfinity x1 remote? The instruction manual does not tell us how.
It is my understanding the xfinity remote is designed only to control comcast set top box and TVs. It also can control audio receivers. It is unlikely you can control a DVD player with it.
At best you could try and use the programming instructions on page 5 of the manual and see if it picks up your DVD player. Otherwise it might be better to use the existing remote controller you have and program the Comcast set top box to it. You need to find the codes from the programming instructions of the original remote control and you will also need to know the model number of your comcast box.
Hope this helps.
https://x1.comcast.net/webportal/assets/pdfs/RemotePairingGuide4.26.11.pdf
Sep 12, 2014 | Televison & Video
I need the 3 digit code for ge universal remote model RC24912-A for sony dvd player
Code lists and manuals for GE remotes are available from http://www.jascoproducts.com/support/universal-remote-codes.asp . The 3-digit code list is here: http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit.pdf . The Sony DVD player codes to try are 166, 320, 321, 322, 361, 389, 399, 909 . (Sony DVD recorders may use 302, 321, 322.)
However, the codes programmed into a universal remote are limited to those for devices released 6 months or more before the remote was programmed. If your DVD player is newer than your remote, you may need a newer universal remote.
I hope this helps.
Jul 24, 2011 | Universal Remote Control GE174Universal...
I have a Panasonic DVD-35 player. Lost the remote. Have programmed my Comcast remote to work and it does. Problem I have is I need to get to the SETUP screen to make an audio change. Cannot get to screen....
hi,
u didn't mentioned the model of comcast remote.if it is DVR 3 device then you can control panasonic dvd through it. the programming code is 20490
if its comcast DVR 3 divice univeral remote control then try these code 0490,0632,1490,1907
ok
Jan 05, 2011 | Panasonic DVD-S35 DVD Player
Program comcast remote to dvd player
THIS SITE HAS MANY CODES FOR MANY REMOTES. IF IT DOESN'T HAVE YOURS PLEASE LET ME KNOW AND WE WILL FIND IT A DIFFRENT WAY.
http://www.xdiv.com/remotes/
IF THIS DOES HELP CAN YOU PLEASE RATE ME.
( I GUESS IT IS IMPORTANT FOR THIS SITE)
Feb 23, 2010 | Televison & Video
Trying to program comcast remote to work with my toshiba SD-V290. Need the remote code???
http://www.comcast.com/corporate/customers/customer_support/remotes.html go there and click the remote your using and then find the brand and get the code
Jul 12, 2009 | Toshiba SD-V296 DVD Player/VCR
Need Comcast Remote Code for Samsung DVD-V1000
I just programmed my comcast remote for my Samsung v1000, My comcast remote is very similar to the 3-in-1, but has a few more buttons on it (on the Comcast site, my remote looks like the DVR 3 remote, but I don't have a DVR). The code I used was 21044.
By using this code, the play/stop/rewind/ff buttons all work. I didn't test the record button. The Info button worked as "Display" and Exit button to work as Audio Source (HiFi/Mono). However, the Volume and Channel controls did not work.
I hope this helps.
Feb 19, 2009 | Samsung DVD-V1000 DVD Player/VCR
Need Memorex MVD2045 5-digit remote code
This code worked for me with the Comcast DVR-3 and the Memorex 2042 DVD player: 20831
It may work with the MVD2045 as well.
Jan 17, 2009 | Memorex MVD2042 DVD Player
Need help finding DVP3140 remote programming code for comcast universal remote
Since the codes that Comcast gave you did not work, there is a very high possibility that the remote control is not compatible with the DVD player. You cannot expect universal remote control to work with all devices, regardless of its make. Philips does not have codes for this DVD player because it is the maker of the universal remote control that sets the codes.
Mar 24, 2008 | Philips DVP3140
Codes for a coby dvd player
I sucessfully programed the AUX button on my Cable remote to my Coby DVD player (model DVD-227) using code 21107. You can also try these codes: 20778, 21086, 21351.
I hope that helps!
Nov 01, 2007 | Radio Shack 15-2104 Remote Control
Program codes
hitachi colour plasma television model name P50T01U is show remote lock .how i unlock the lock menu.
Oct 15, 2007 | Hitachi CLU-5713TSI Remote Control
GE 1101P DVD Player Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
