Question about Cisco IPCX OR IP IVR 3.5 3.Y MS SQL SVR 1 PROC SW *2% DISCOUNT COD/WIRE Sys (IPCXIVR3YDB1PS1)
Dsds WARNING: local host name (mail) is not qualified; see cf/README: WHO AM I?
Tip
How to Setup Linux Mail Server
<p><span>Email is an important part of any Web site that you create. In a home environment, a free web based email service may be sufficient, but if you are running a business, then a dedicated mail server will be required. <span>A mail server is an application that receives incoming e-mail from local users (people within the same</span><span> </span><span><span>domain)</span> and remote senders and forwards outgoing e-mail for delivery, as example Microsoft</span><span> </span><span><span>Exchange</span>, Gmail,</span><span> </span><span><span>etc.</span></span></span><span> <span> </span></span><span><span>The system uses</span></span><span><span> </span></span><span><span>SMTP </span></span><span><span>(Simple Mail Transfer Protocol) or <span>ESMTP </span>(extended SMTP) for sending e-mail, and either</span></span><span><span> </span></span><span><span>POP3</span></span><span><span> </span></span><span><span>(Post Office Protocol 3) or <span>IMAP</span></span></span><span><span> </span></span><span><span>(Internet Message Access Protocol) for receiving e-mail</span></span><span><span>. </span></span><span><span>In windows forum</span></span><span><span> most of workstations are use Microsoft Exchange server or outlook express. In Linux forum there have also an easiest option to send and receive mail. In Linux configuration of mail server is easy flexible too.</span></span><span></SPAN><br> <p><span><span> </SPAN>In most of Linux workstation RedHat Linux are used for their Server. In RedHat Linux we use sendmail to create a mail server that will relay your mail to a remote user's mailbox or incoming mail to a local mail box. On our RedHat we will find sendmail's configuration file as /etc/sendmail.cf. If you download and compile sendmail you would find it in /etc/mail/sendmail.cf. To configure sendmail you have basically 2 options. Either you edit the sendmail.cf file directly or you create the sendmail.cf from an m4 file such as sendmail.mc. Here to explain the process I will list the steps to produce a custom sendmail.mc file.</SPAN><br> <p><span></SPAN> <br> <p><span><span><b>SendMail Configuration:</b></SPAN></SPAN><span> </SPAN><span><span> </SPAN>In Redhat Linux dovecot and sendmail packages are used as service demon for Mail server. At first I install the available sendmail RPM package by YUM and also the dovecot RPM. After installation first I have edit the sendmail .mc file. After installation of sendmail package it locates as sendmail.mc in /etc/mail. In the sendmail.mc file I have find the line DAEMON_OPTION and edit it with # before the line to uncheck it. Then I find Local Domain and edit it also with the system FQDN. After editing save the sendmail.mc file. After exiting from sendmail.mc I moved this .mc file to sendmail.cf with m4. Here the SendMail configuration is complete. Then I go to the /etc/dovecot.conf file and edit it. I just find the protocol line and uncheck this line. After that I save this .conf file. After all configurations I have start the service demons with chkconfig command and restart the both services. And the mail server was going on swiftly.</SPAN><br> <p><span><span> </SPAN>So it is very easiest job to configure a mail server in RedHat Linux enterprise server.</SPAN>
on Mar 21, 2011 | Computers & Internet
Tip
How to setup your email into your iPhone
First, you need to know your IMAP incoming and outgoing mail servers. These servers can be provided by your email service provider. Once you have these info, you may follow the steps below:
1.Go to 'Settings' on the main menu on your iPhone.
2. Click on Mail, Contacts, Calendar...
3. Select Add Account and tap 'Other'
4. Add mail account and then fill out the lines with your name, e-mail address and password then tap 'Save'.
5. Select IMAP and then use the information below:
* Incoming Mail Server *
- Host Name: type the IMAP incoming server
- User Name: type your complete email address
- Password: your e-mail password
* Outgoing Mail Server *
- Host Name: type the IMAP outgoing server
6. Tap Save button.
Thank you!
on May 03, 2010 | Cell Phones
Error message when using my new Microsoft Windows Mail program-
You are supposed to put the fully qualified domain name of the mail server in the SMTP server field, and the POP3 server field, like mail.acmellc.com and pop3.mycompanyname.com. Contact your mail service provider if you are not sure what the server names are.
Aug 05, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Why can't I access my ISP's resources, such as their mail and news servers on my RO318?
If the servers have simple names like 'mail' or 'news', the problem may be that the ISP's domain suffix is not being added to these names before DNS lookup. Add your ISP's domain suffix as Domain Name in the RO318's System menu. In addition, the ISP may be looking for a particular host name for your account, in which case you should enter the host name as the System Name in the RO318's System menu. Example: Consider the following account with the ISP "earthlink.net". 1. Host Name: C-223344-A 2. Domain Name: www.earthlink.net Mail Server mail Although the ISP lists the name of their mail server as 'mail', the fully expanded name is actually: mail.earthlink.net If the ISP automatically provides the domain suffix to your router, the router will append the domain suffix to DNS requests. If not, you can try one of these methods: 1. In each application (such as mail client or news reader), list the fully expanded server name, 2. Manually configure DNS parameters in the network settings of each of your PCs, and enter the domain suffix manually.
Feb 19, 2006 | NetGear RO318 Router
Cannot Send or Receive Email
This may happen if your Internet connection uses dynamic DNS. Change the email application to use a fully qualified domain name for the login. A fully qualified name is composed of both the host and domain. Correct: yourusername.aol.com Incorrect: yourusername The correct fully qualified name can also be derived by putting your router's username and domain name together as they appear on the router's setup screens. E.g., if username = sueandfred, and domain name = aol.com, then the fully qualified name = sueandfred.aol.com. (Note the dot between the username and domain.)
Feb 19, 2006 | NetGear DG814 DSL Modem Internet Gateway...
Some errors
Download the ATA PCMCIA/CF-Card update drivers* (file name MP8Pcm.exe) from ftp://ftp.necsam.com/pub/versa/mobilepro/. Click on the link to download. After the files are extracted, follow the installation instructions in Readme.txt. *This module requires 40KB of internal RAM memory. If the MobilePro has been Hard Reset or Main memory has been erased due to main/backup battery low, this module should be re-installed.
Sep 15, 2005 | NEC MobilePro 800
Some errors
Sep 15, 2005 | NEC MobilePro 770
Computers & Internet Logo
29 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
