Question about Toshiba Satellite 1800-S204 Notebook
Need to restore my laptop to factory settings.
I have attempted holding the "0" key as well as "F1" and "F8", none of which restore my laptop to factory settings. Note: I do not want to system restore it to an earlier date, I want factory settings. Also, I know that I will lose all data by doing this, which is not an issue. Thanks for the help in advance. :)
  • Bob Thomson Jan 12, 2013
    Note: my model number is:L45-S7423
  • Toshiba Master
  • 32,281 Answers
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Posted on Jan 12, 2013
  • 2 more comments
    I stated in the op that I've already tried this...it doesn't work.
  • Chris Hingee
    Chris Hingee Jan 13, 2013
    You need to get a recovery CD for your model Toshiba laptop from the Toshiba support WEB site.
  • Bob Thomson Jan 13, 2013
    I am 100% sure that is not the only way to resolve this issue.
  • Chris Hingee
    The easiest way is to get a recovery CD. This has the Windows OS and the laptop's device drivers. The otherway is to get a Windows installation CD and use the Windows installation code that is printed on the Windows label on the bottom of your laptop and after the Windows installation you need to download and install the laptop's device drivers from the Toshiba WEB site.
Toshiba PSLC8U-03701Q factory restore
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to
hope this helps you
Mar 18, 2012 | Toshiba Satellite L305D Notebook
Hp laptop has blinking red square above touch pad, comp. won't allow for reboot or restoring to factory conditions
If you do an illegal shut down which is power off by holding down the power switch for 8 seconds. The HP computer will then boot with the scandisk program, which will restore your hdd to perfection. Windows XP or later now use 'system restore' to rearrange registry from a previous calender date that the computer used to work perfectly.
Feb 09, 2012 | HP Pavilion dv2911us PC Notebook
Cant restore to factory settings tried 0,f1 and f8 none work
When your Toshiba Satellite laptop goes on the fritz, there are several instances where the best solution is to delete everything and start over. If your system frequently crashes or you can't remove a specific virus, you may want to restore the laptop back to original factory settings. While the easiest way to restore the system is to use the operating system restore disc, it is possible to restore the system without it. Each Satellite laptop also includes a hard drive recovery utility that lets you restore the operating system without the restore disc.
1. Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
2. Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
3. Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
4. Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
5. Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
6. Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
I hope you find it very helpful. Thank you for using fixya.com
Aug 16, 2011 | Toshiba Satellite Pro L300 Notebook
How do i reset my toshiba satellite A135-S4427 to when i bought it
This should work on every recent Toshiba laptop (). - Start with you laptop turned off.
- While holding down the 0 (zero) key tap the power button.
- When you hear a beep, release the 0 key.
- select Yes to continue with the system recovery.
- Select Recovery of Factory Default Software and Next.
- Select Recover to out-of-box state and Next.
WARNING: the procedure will delete all data on your hard drive!!
Feb 28, 2011 | Toshiba Satellite A135-S4427 Notebook
I am trying to reset my toshibe m45 s165 to its factory settings, but when i try the whole press "0" and power at the same time, the laptop keeps turning off since im holding the power button,...
Do not hold the power button down while pressing the "0" key - it'll shut the computer off again. You just need to push it once to turn the power on and then hold the "0" key immediately after you push the power button on - just like turning on the laptop, but this time you're holding the "0" key down.
Feb 05, 2011 | Toshiba Satellite M45-S165 Notebook
System restore factory settings no cd
Toshiba has built in system recovery partition in your hard drive
Make sure to back up important files in your Laptop to usb or portable hard disk before doing this.
Warning: In using System Recovery you files will be deleted, your laptop will be back to its factory settings
To access the Toshiba recovery partition, power off the laptop. Hold down the 0 (zero) key and turn the laptop on. Keep holding down the zero key until the TOSHIBA logo appears, where you should start tapping the zero key repeatedly. Stop if the unit beeps or when the TOSHIBA logo disappears. The screen should flash ** HDD RECOVERY MODE ** for a split second, then load the Toshiba recovery program right from the hard drive.
Feb 01, 2011 | Toshiba Satellite A45-S120 Notebook
How can i restore my toshiba A505-s6960 to factory settings?
Press and hold the "0" key on the keyboard while powering on the computer.
Jan 26, 2011 | Toshiba Computers & Internet
How to reset to factory settings a toshiba satellite A305-S6829 with Vista ? (pressing 0, or F8 didn't bring me far!
Note that this erases all data, and reloads all factory default software. Be sure to back up all your important personal data beforehand!
Dec 31, 2010 | Toshiba Computers & Internet
Restoring to factory settings
to restore the factory setting you must boot the laptop off of the restore CD it will wipe the drive and reinstall the factory software and drivers just walk through the prompts. holding the f8 key will not restore the laptop to factory settings it just allows for options during windows startup
Oct 13, 2009 | Fujitsu AMILO D-7820 Notebook
Restore to factory settingswith out cd
for toshiba factory reset without disk like this
Toshiba: BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
Pls rate me FIXYA for help !
Apr 11, 2009 | Toshiba Toahiba Satellite A60 A65 Series...
Toshiba Satellite 1800-S204 Notebook Logo
627 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
