How do i remove the filter on my hotpoint aquarius+ wmf720?
  • 90 Answers
SOURCE: How to remove top panel and front facia on a Hotpoint Aquarius WDF451 washing machine
Un plug it. There should be small screws either at the bottom of the panel on the front or there is separate panel that comes off the top back. If the back is one solid piece top to bottom, then the control panel lifts out and hinges up when the two small cross tip screws are removed from the bottom outside corners of the control panel..
Posted on Feb 10, 2008
  • 3 Answers
SOURCE: hotpoint aquarius drum makes a noise and is stiff at one point
You take the top off. A couple of screws on the back of the unit, then the top slides off backwards
Posted on Oct 23, 2008
  • 15 Answers
SOURCE: Where are the filters in Hotpoint Aquarius WF340 washing machine
if you dont have one in the front under the lid your model comes with a slip on filter that goes on top of the aggitator you schouldnt run it without it because ge pumps have a tendacy to freeze up with the lint from your clothes especcially levis hope this helps
Posted on Dec 18, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint aquarius wf325 filter problem, Blocked maybe?
You are correct as to the location of the filter.
Remove rear panel, locate large black hose at right lower side.
Remove securing clip and hose, inside you will see the plastic filter, remove and clean filter, note location of plastic ball.
Refit filter and hose, and securely fasten hose back on.
When you remove hose, watch out for water, as there will be some in the hose.
water test before fitting panel back on.
Plz rate my solution
Thanks.
Posted on Jan 08, 2009
  • 135 Answers
SOURCE: i cant find my filter
It is either behind the kick plate at the front or in the pipe on the bottom of the drum which runs to the pump.
This is acessed by removing the panel at the back.
Hope this helps & thankyou for using Fixya.
Posted on Jan 19, 2009
Where is the pressure switch located on a hotpoint WMF720
SHOULD BE ON LEFT SIDE OF MACHINE IN THE PANEL ON TOP? ITS A ROUND PC WITH A PLASTIC TUBE RUNNING INTO IT
Aug 11, 2014 | Hotpoint Washing Machines
My hotpoint aquarius wmf720 keeps flashing either door or f-10, can anyone help??
Please read in full before attempting any repair.
p.s. Before working on machine "turn of the power".
Only carry out if you are confident that you can carry out safely.
Note check small black hose to the air pressure switch is connected,
When machine is turned upside down, the hose has a tendency to come off.
If unsure call a service engineer.
My machine just had the flashing "door" fault.
On carrying out fault finding checks,
I Found that the main PCB had a built up dust.
This dust was in black lines going between components of the board.
Cleaned around components of the board with a small soft brush.
assembled & tested okay 2 months ago & still working.
Mar 31, 2013 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WMF720 Aquarius+
Hotpoint WMF720 Aquarius washing machine is leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 28, 2012 | Hotpoint Washing Machines
Could you please tell me where i can find the filters on the hotpoint aquarius extra WD63? Thank you
Remove rear panel completely from washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside the hose.
Oct 21, 2010 | Hotpoint Aquarius WD63 Front Load...
Where is the filter located on a Hotpoint Aquarius WM63 washing machine?
Remove lower rear panel of washer.
Locate and remove the large black hose from bottom of drum, remove and clean the filter inside the hose.
Oct 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I have a Hotpoint Aquarius 1100 washer dryer and think the filter might be blocked but I cannot locate the filter to check it. Any ideas?
Remove the lower rear panel of washer.
Remove and clean the plasic filter inside hose..
Also check the pump for a blockage as well.
Thisn should solve your problem.
Dec 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint 6kg Aquarius , pre wash keeps flashing, so it is not washing......can you help
Check and clean the pump filter.
Remove lower rear panel of washer, remove large black hose on bottom of drum,remove and clean filter inside, alsr remove hose onto pump, and check for obstruction here and in the pump.
Please rate my solution.
Thanks.
Nov 11, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Where is the filter on hotpoint aquarius extra wwm39
Remove lower rear cover of washer, you should see a large black hose attached to bottom of drum.
Remove hose and clean plastic filter inside hose.
Thanks.
Sep 11, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius extra filter
Normally in front of machine.Remove down plastic cover and then you see pump/filter,open and clean and make sure pump rotor is free to run.Jan
Feb 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WD440 Washer/Dryer
remove bottom rear panel. you will see a large diameter hose going from tub to pump. undo this hose at the tub end - lots of water will come out. filter is inside this hose. remove and clean
Jul 17, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
108 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
