Question about Utilitech 1/2 HP Convertible Jet Pump 1/2C-JET
Utilitech 1/2 hp sump pump wont turn off
Pump wont turn off. it has a separate plug for the float. I had an old float assembly with a plug and screwed that on and it worked twice, but then the pump was stuck on again.
Motor would not start intermittently. Disassembled to determine possible problem.
The oil has to be there. Intermittent starting is usually the float switch hitting something in the sump. If the pump motor has a capacitor on it, replace the capacitor.
Aug 20, 2015 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Sump pump does not go on all the time have to shake pipe to get it going so water doesn't overflow
There should be a float switch in the pit, sounds like its getting stuck and when you shake it it activates. Check the switch, the rod, etc.
Mar 01, 2015 | Utilitech 0.33-HP Thermoplastic...
Why wont the pump turn on
If the pump is plugged in through a float switch the switch may be bad- try plugging the pump in by just the plug for the pump itself if possible -if that works then you need a new float switch.
Jun 10, 2014 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Pump won't shut-ff
Hi Ron...
Check your float switch....sometimes they can get stuck to cause this problem of not shutting down after draining the orginal water.
Take the float switch and move it up and down...this may help to clear the stuck switch inside of the float
Bud
Apr 24, 2013 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Pump not working
If power is going to pump and float switch is good, motor has fried, time to get a new one.
Oct 07, 2012 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
HOW TO TURN ON PUMP??
The pump should start by itself and shut off by itself as well. The float switch needs replacing. If new, return it. If you want to test the pump, separate the two plugs and plug in the one that leads to the main pump body.
Aug 28, 2011 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
Stopped working
The float is usually the culprit if it is not turning on. I f you have a floating ball type float switch try lifting it up and shaking it to see if pump starts running. These micro switches stick after several years use. If you have a round canister on the side it is a pressure activated switch that also has a micro switch inside that completes the circut when the pressure on the diafram is enough to click the switch. I f it has a float on a rod it has a switch at the top of the pump that shuts it off when at low level, and turns it on at high water level. Most pumps have a two part cord. The pump plugs into the float control switch, so it does not get power till the float switch clicks on. If you have a two part plug, then separate them and plug the cord in that leads directly to the pump body. This will tell you if the pump is working. If it is then replace the float switch assembly. Also there is either a few screws holding the pump screen on to the pump on the underside. Some simply snap fit to the pump body. Often I will find stones, wood chips string etc. in the pump impeller. That is what pumps the water by squeezing it into the small 1 1/4 output orifice. That about covers it. Please post to fixya.com if it does, so I get the credit for the solve. Let me know if you do need more advice. Good Luck!!!
Mar 18, 2011 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
I have a flotec model 1m03w fp053200a-o8 1.5 hp sump pump. It run all the time now, the only way it shuts off is if its unplugged. Do I need to replace it, or can it be repaired? Thanks for your time
If you have the pump pictured, there is a float switch in the big round thing that floats. When this float drops, the switch should open and pump should shut off.
Make sure that the pump plug is plugged into the piggyback type float plug.
Jan 03, 2011 | Flotec FP0S3200A-01 1/2 HP 3,200 GPH...
Damaged plug on end of float switch
if it is just a small length of cord you can just attach any cord to it from any old appliance, if you feel that it needs to be waterproofed go to home depot and by one for wet areas
Sep 18, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Utilitech 1/2 HP Convertible Jet Pump 1/2C-JET Logo
61 people viewed this question
Top Utilitech Plumbing Experts
Paul Carew
jhnolson
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
