Question about LG LRBN20510WW Bottom Freezer Refrigerator
Noisy vibration Our LG fridge makes a vibrating sound that has become progressively louder. I took off the aluminum back panel and saw the condenser, condenser coils and the fan, but no other moving parts. The noise seems to be coming from inside the fridge but I can't figure out where. The fridge seems to be working fine but with this noise I am aware of how frequently it runs and I wonder if this is normal.
  • 1 more comment
  • pdstrand Jan 23, 2009
    I don't see ice but after reading lots more of the (ahem) virtues of the LG fridge on line, I listenend int the freezer and the noise was much louder from there. So, a good defrosting will help?
    Paul
  • pdstrand Jan 26, 2009
    Thanks John
  • mpkucher May 11, 2010
    Is there a build up of ice on the rear wall of the freezer?
    How long have you owned it and when did it start. I had a similar problem, which was the lower fan blades hitting ice build up where you can't see it.
    Scholar:
  • 70 Answers
Heater of defrost controls appear to be bad. If you need to melt out by hand then your auto defrost is not working. These are now solid state with sensors. Old friges were must easier to repair.
Posted on Jun 29, 2009
  • Kendall Clendenen
    Kendall Clendenen Jun 29, 2009
    This is sounding more like incomplete defrost problem that LG needs to address. If there is ice build up and defrost is working then it is a factory flaw. There should never be ice build up in a properly working frig.
    Sniper:
  • 109 Answers
I had the same problem. Here is my fix: - remove both side rails inside the freezer (3 screws each) - remove the back panel inside the freezer (2 screws) - I found there a large (4 inch x 4 inch x 6 inch) block of ice that was interfering with the fan - gently remove the ice (I used a hair dryer) - clean and dry all parts - re-install back panel and side rails
Posted on Jun 12, 2009
  • 3 Answers
Remove the back panel inside the freezer (if there's a removable panel there. There is a fan behind it - may be source of your problem.
Posted on Jan 26, 2009
New LG French Door fridge w/fzr on bottom a buzzing sound is coming from the unit.If I open a door it stops but comes back when I close. I can apply pressure on the casing and quiet it. Any ideas?
Try attaching a clothes peg to the condenser which is the ********* attachment on the back of the unit.first off make sure that the appliance is level as any vibration will cause the noise you're describing.N.J.T.
Oct 25, 2017 | LG Refrigerators
Frigidare freezer making buzzing sound like a motor
You hear the evaporator fan that is probably rubbing on some ice buildup. Remove the rear panel in the freezer to confirm that there is ice buildup and post back to me.
Nov 17, 2012 | Frigidaire FRS23KF7AB Side by Side...
Kenmore Elite side by side model 596.76523500 serial 10518811je makes buzzing noise from bottom area. If I remove the bottom access cover and press the black grill piece upward so as to apply a good...
the noise is from vibration,pull out the machine,remove the back bottom panel and see if anything is loose,the condenser fan and compressor are in the back and when they are running something is vibrating and making the noise,just watch out for the fan blade,it's spinning so fast you can't see it,if you can't find anything loose back there you can try to wedge something in between the condenser coil and the frame of the fridge to stop the noise,all it is is vibration,
May 14, 2011 | Kitchen Ranges
Westinghouse virtuoso fridge is noisy after leaving the freezer door open several hours
First analyze from where you are getting the sound.
1)Check the fan at the back side of the freezer.Is it making noise.Remove it and put some oil so it will rotate without sound.Check for the bending and straighten it and see it
doesn't hit on body.
2)compressor motor may vibrating a lot making noise to the condenser coils.It makes the full fridge to vibrate and makes noise.Adhesive stickers will soften them.If still problem persist coil could be damaged.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 06, 2010 | Refrigerators
My fridge has become very noisy? Could you advise?
The fault can be the vibration of the compressor motor radiating the noise to the condenser coils. So it may be hitting against the walls of the fridge and you are getting this noise. Also tthe compressor makes tteh vibration that transmits to plastics, trays at the bottom of fridge and the rear mounting. Use good adhesive stickers to soften them.
Aug 30, 2010 | Hotpoint FFA60 Bottom Freezer Refrigerator
Machine vibrating and grinding at the bottom of the machine
if noise stops when you put youre hand on bottom panel(vibration) then it will probably need a new drain pump as they wear out they can become noisy and make the panel buzz.
Oct 07, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Maytag side by side fridge makes vibration noise
Mine is a different model, and less than three years old, but the vibrating noise was really annoying. I would shift the unit or the door slightly, and it would stop for a while, as you reported. I took a few minutes, applied pressure to different areas, up and down, inside and out. The noise was louder near the floor. I removed the plastic grill and applied upward pressure on the wires covering the coils - it was loose. I noticed an accumulation of dust, and vacuumed as far as I could reach around the underneath area; also pulled fridge out and vacuumed a dust-covered vent on the back near the floor. Was planning to insert some kind of wedge under the loose part, but when I put everything back in place, the vibration stopped - now I only hear a gentle hum. Seems I did something right in this process.
Apr 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Feb 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
LG flat screen TV speakers make a vibrating noise
I have this problem with my 37LG30.
They all seem to have the same factory flaw.
The plastic bezel and rear is vibrating against itself I have found.
Tonight, just now, I just took all the front bezel screws out,(from the back) loosened the other 4 big screws in the rear center(I don't recommend removing them)and loosened the stand screws also and tried separating the bezel from the back as I went around the set. This did not really help much except around the bottom where the noise/vibrating comes from-the speaker area.
The two plastic pieces are vibrating against one another.
The vibrating was coming from the speaker area without doubt.
The next thing was to try separating at the bottom where the speakers are with my fingers and a stiff metal nail file carefully..fingers seemed to work best for me.
As I separated the front bezel from the rear housing (at the speaker location)most if not all the buzzing/vibrating /distortion went away.
I then inserted small pieces of cotton (you can use felt, or similar I suppose) and buttoned it all back up;put the screws in
Almost all the distortion and speaker buzz/vibratingis gone except on very low frequencies.
good luck!
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
LG LRBN20510WW Bottom Freezer Refrigerator Logo
1,302 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
