Question about Veo Stingray
Veo Stingray Webcam 330
I have a duplicate CD-R, installed in computer, open program it says that the cam is not connected, but it is. So, Yooperbud, I hope you can help me !!
    President:
  • 8,637 Answers
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 28, 2009
  • Weldon Dube'
    Weldon Dube' Feb 06, 2009
    Did you unplug the camera from the USB port and then reinstall the CD Software Program and when it asks you to plug in the the camera in the USB port, then and only then do so. This has been the problem with most of the one I've fixed. Bud
Why am i getting an error message
this is the most solution:: I had the same problem:
"Click on Start->Control Panel->Add or Remove Programs and uninstall the Veo Stingray software driver. Also, uninstall the Veo Digital Studio.
Unplug the Veo Stingray from the computer.
IMPORTANT! If you are connected to the Internet (such as through a dial-up modem or cable modem/DSL) log off from your Internet Service Provider and disconnect any telephone cords or Ethernet/Network cables from your computer. This will prevent Microsoft Windows Update from attempting to update your Veo Stingray software driver through Microsoft Windows Update.
Place your Veo Stingray CD ROM into your computer.
Click on Start->My Computer. Look for your Veo Stingray CD ROM drive.
Right-click on the Veo Stingray CD ROM icon and then select Open.
Go to the E:\DRIVERS\APPBIN folder and double-click on a file named cleanup. (You can also download the cleanup file from: ftp://home.fiasj.net/xirlink/ibm/ibmcleanup.exe)
In the cleanup program, press the "Scan and Delete" button in order for it to begin.
After the cleanup program has finished, click the "Exit" button and restart the computer.
Reinstall the Veo Stingray from the CD ROM, restart the computer, and plug in the camera after the computer has restarted.
good luck!
May 06, 2013 | Veo Advanced Connect Webcam
Receive error code when trying to take snap shot with VeoAdvanced
I hope this sollution helps:
""Click on Start->Control Panel->Add or Remove Programs and uninstall the Veo Stingray software driver. Also, uninstall the Veo Digital Studio.
Go to the E:DRIVERSAPPBIN folder and double-click on a file named cleanup. (You can also download the cleanup file from: ftp://home.fiasj.net/xirlink/ibm/ibmcleanup.exe)
After the Veo Stingray has finished installing, try the Veo Digital Studio program again and click the "Take a Snapshot" button.
If it works, you can reconnect your telephone cord or Ethernet/Network cable to your computer. Microsoft Windows Update will not attempt to update the Veo Stingray driver again."
It might also be a java problem, go to Add/Remove Programs, uninstall all versions of Java, and try reinstalling."
Jun 23, 2009 | Veo Advanced Connect Webcam
Veo stingray web cam with no cd-rom or disk to install the software
I found the drivers you need at: http://www.softsci.com/veodrivers.htm They have drivers for serial numbers 330 and 328 so make sure you choose the correct item.
Nov 23, 2008 | Veo Stingray
Veo advanced
Oh for goodness sake why cant the message read "you broke it .... throw it away and get a new one" ?? At least u would understand that !!!!!!!!!!
Sep 28, 2008 | Veo Advanced Connect Webcam
Veo stingray webcam vista compatible driver
Ok what you need to do is go to "computer" and right click on the drive that has your Install cd in it. Next click Explore. Then right click on "AUTORUN" and select properties, Under The Compatability tab change it to run in XP service pack 2 wait for it to switch, now click on AUTORUN and follow the steps. Worked great for my veo stingray 330
Feb 19, 2008 | Veo Stingray
Veo stingray webcam
This fix will work for all of the VEO Stingray problems because it gives a good driver download site and it tells you step by step how to get your cam to work with VISTA Good Luck and let me know if this fixed your problems.
1.Go to this site and download the driver you need: http://www.softsci.com/veodrivers.htm
2.Download it to your desktop
3. Don't unzip, install, or plug in your cam yet
4.Search for this in your start menu: Program Compatibility Wizard
5. Of the three choices click the one that says look for the program manually
6. Choose the option for XP
7. Choose the 680 x 420 or whatever it is not the 256 colors
8. Choose to run as administrator
9. Click next and it should change your screen to a real big resolution and then it will start to install the driver
10. Go through the install wizard
11. After it has loaded plug in your camera
12. Try a program that it is supposed to work with
13. Finish the Compatibility Wizard
now everything should work for your cam.
This works with all of your programs that vista will not run.
Dec 20, 2007 | Veo Stingray
Where can i downlad software for my veo stingray webcam
Here are some drivers to download.
Nov 20, 2007 | Veo Stingray
Veo stingray
Download the latest drivers here
Nov 05, 2007 | Veo Stingray
Veo stingray webcam
Normal 0 You need to go to the manufactures site and download the VISTA driver for the camera. Then follow the info below to install the program.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Oct 14, 2007 | Xirlink Promax Webcam
Veo Stingray Logo
35 people viewed this question
Top Veo Computers & Internet Experts
micky dee
Lyle Siemens
Lyle Siemens
Are you a Veo Computer and Internet Expert? Answer questions, earn points and help others
